Hello
I try to install driver on FEDORA 35, Ubuntu 21.10
Zbook G8 with t1200
Same issue on 510.47.03
470.103
Installed from fedora official repositories and also from *run from nvidia.com
Thank You
nvidia-bug-report.log.gz (95.7 KB)
Hello
Zbook G8 with t1200
470.103
Thank You
Seems like there is a real issue behind:
[ 7.773318] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 7.773614] nvidia 0000:01:00.0: can’t change power state from D3cold to D0 (config space inaccessible)
[ 7.773711] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 7.773724] NVRM: The NVIDIA GPU 0000:01:00.0
NVRM: (PCI ID: 10de:1fbc) installed in this system has
NVRM: fallen off the bus and is not responding to commands.
[ 7.773772] nvidia: probe of 0000:01:00.0 failed with error -1
[ 7.773789] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 7.773790] NVRM: None of the NVIDIA devices were initialized.
[ 7.773912] nvidia-nvlink: Unregistered the Nvlink Core, major device number 508
Do you confirm that you aren’t using any dedicated xorg.conf snipet ?
@kwizart it’s a kernel bug in kernels 5.13, 5.14 and 5.16 (don’t know about 5.17) which affects mobile intel core-i 11th gen systems so that the nvidia gpu is turned off after boot and can’t be turned on. Don’t know whether this is a bug in pcie pm or acpica.
