NVIDIA OpenGL Driver cannot be found
I have update to a Aourus Geforce RTX 2080 Super Waterforce from a GTX 1060 and since that moment I haven’t been able to play X-Plane 11.
I’m getting this error after a few minutes:
The description for Event ID 1 from source NVIDIA OpenGL Driver cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Unable to recover from a kernel exception. The application must close.
Error code: 3 (subcode 7)
(pid=11392 tid=12300 x-plane.exe 64bit)
Visit http://www.nvidia.com/page/support.html for more information.
The message resource is present but the message was not found in the message table
I’ve reviewed lots of forums, web, etc and I think I’ve tested everything, from installing a clean OS, different driver versions and including TdrDelay in the registry Key.
I don’t know what to do. I thought I have bought a very powerful card but the I can’t enjoy one of my favorite hobbies.
This is my system summary:
[System Summary (J:\PAP01.nfo)]
Item Value
OS Name Microsoft Windows 10 Pro
Version 10.0.18362 Build 18362
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name PAP01
System Manufacturer Gigabyte Technology Co., Ltd.
System Model Z390 AORUS MASTER
System Type x64-based PC
System SKU Default string
Processor Intel(R) Core™ i9-9900K CPU @ 3.60GHz, 3600 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. F11c, 12/18/2019
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Gigabyte Technology Co., Ltd.
BaseBoard Product Z390 AORUS MASTER-CF
BaseBoard Version x.x
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume7
Locale United States
Hardware Abstraction Layer Version = “10.0.18362.752”
User Name PAP01\root
Time Zone Romance Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 26.2 GB
Total Virtual Memory 33.5 GB
Available Virtual Memory 4.73 GB
Page File Space 1.56 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Thanks in advance for your support!
Regards
