hello and Ofcourse i’m sorry because my english is not good (for now^^).
I’ve got problem with my GPU(1060 StriX 6gb) on Fedora 25.
GPU is still on Performance level 0-1 in PowerMizer. Even if i turned on “persistence mode” (sudo nvidia-smi -pm 1) and i changed “power limit” (sudo nvidia-smi -pl 156) (Power limit for GPU 0000:01:00.0 was set to 156.00 W from 78.00 W.All done.).
But GPU still using 6-11W.
Also nvidia-settings does not save any changes so after restart i’ve got settings without any changes.
If i changed anything in xorg.conf (in Nvidia section) Power Limit will stuck on lvl 0.
Some images:
Nvidia-settings(PowerMizer:
https://postimg.org/image/7jtctu7iz/
Nvidia-smi:
https://postimg.org/image/s2upzjc7d/
SMI log:
==============NVSMI LOG==============
Timestamp : Wed Dec 7 14:14:52 2016
Driver Version : 375.20
Attached GPUs : 1
GPU 0000:01:00.0
Product Name : GeForce GTX 1060 6GB
Product Brand : GeForce
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-7217bfb2-65c3-4acc-5c24-abe990e8c0f9
Minor Number : 0
VBIOS Version : 86.06.0E.00.0A
MultiGPU Board : No
Board ID : 0x100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.03
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1C0310DE
Bus Id : 0000:01:00.0
Sub System Id : 0x85AC1043
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 5000 KB/s
Rx Throughput : 1000 KB/s
Fan Speed : 0 %
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Sync Boost : Not Active
Unknown : Not Active
FB Memory Usage
Total : 6101 MiB
Used : 238 MiB
Free : 5863 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 5 MiB
Free : 251 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 3 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 27 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 99 C
Power Readings
Power Management : Supported
Power Draw : 7.62 W
Power Limit : 156.00 W
Default Power Limit : 156.00 W
Enforced Power Limit : 156.00 W
Min Power Limit : 78.00 W
Max Power Limit : 182.00 W
Clocks
Graphics : 253 MHz
SM : 253 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2025 MHz
SM : 2025 MHz
Memory : 4104 MHz
Video : 1708 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 1111
Type : G
Used GPU Memory : 3 MiB
Process ID : 1415
Type : G
Used GPU Memory : 74 MiB
Process ID : 1514
Type : G
Used GPU Memory : 115 MiB
Process ID : 2498
Type : G
Used GPU Memory : 0 MiB
Some information:
Motherboard: Asus z170 pro gaming
CPU: Intel i5 6600k
Ram: 16Gb DDR4
GPU: Nvidia Asus StriX 1060 6GB
OS: Fedora 25
Kernel: 4.8.11-300
GPU drivers: NVIDIA 375.20 driver
“Similar” situation we have here:
https://devtalk.nvidia.com/default/topic/980313/linux/force-gtx1080-performance-level-to-reduce-power-consumption-under-linux/
Ofcourse i’m sorry because my english is bad (for now^^).
