nvidia-settings timing out while trying to connect to IP in New York?
I noticed lately that nvidia-settings takes a LONG time to start up. It takes over a minute before it will start. I decided to see what it was doing via strace, and was surprised to find it trying to make a connection and timing out. Here is what I found:
socket(PF_INET, SOCK_STREAM|SOCK_CLOEXEC, IPPROTO_TCP) = 6
setsockopt(6, SOL_TCP, TCP_NODELAY, [1], 4) = 0
setsockopt(6, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0
connect(6, {sa_family=AF_INET, sin_port=htons(6000), sin_addr=inet_addr(“216.21.239.197”)}, 16) = -1 ETIMEDOUT (Connection timed out)
close(6) = 0
This is where it is hanging up while starting. It doesn’t load until this connection times out.
I traced that IP to New York. Why is nvidia-settings attempting to connect to New York during startup?
Because you are powned.
nvidia-settings shouldn’t connect to any IP address in NYC, in fact nvidia-settings sources can be freely downloaded and recompiled.
NVIDIA Co, is located in Santa Clara, CA.
nvidia-settings uses libX11 to connect to two X servers: the display connection specified in $DISPLAY, and the control connection specified by -c on the command line (defaults to $DISPLAY if unset). If libX11 is compiled with TCP support (which it usually is) and the display connection has the form “host:port” or “host:port.display” then it will try to make a TCP connection to that host.
[Edit] Oh, and I forgot to mention that there’s currently a bug that causes it to write the hostname for some of the attributes in ~/.nvidia-settings-rc, namely the color correction settings. If your hostname is set wrong, that might be causing part of the problem. Check ~/.nvidia-settings-rc to see if it has attributes with hostnames that resolve to that address.
I can confirm that nvidia-settings takes enormous time to start (approximately 1 minute or so).
This bug was introduced in 304.64 driver. My nvidia-settings is not connecting to any IP in NY or whatsoever, btw.
PS: i was very pleased with nVidia’s attention to GNU/Linux, but considering total mayhem introduced since 304.64 drivers (maybe in 304.60 too, i just skipped it) i’m considering AMD as a viable alternative for my future computer.
By mayhem i mean blank tty’s (no signal), nvidia-settings not starting properly, corrupted X-session upon starting (blank screen, 1 blinking pixel at left top display’s corner (happens in 1 case out of 10, but still… - never happened before), impossibility to compile kernel module without 3rd party patches for nVidia’s driver (this is absolutely ridiculous and is a serious risk for system’s security) - this happened with 304.64.
I don’t know guys what happened to you, but i am very disappointed.
I see now. This is a result of register.com hijacking undeclared names within my domain. Thanks for the tips. :-)
