Initially, I believed it to be a driver problem and attempted to use different drivers, but I encountered the same error with all of them. Below, you’ll find the output for nvidia-smi and lshw.
$nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$sudo lshw -C video
*-display UNCLAIMED
description: VGA compatible controller
product: SVGA II Adapter
vendor: VMware
physical id: f
bus info: pci@0000:00:0f.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller cap_list
configuration: latency=64
resources: ioport:1070(size=16) memory:e8000000-efffffff memory:fe000000-fe7fffff memory:c0000-dffff
*-display UNCLAIMED
description: 3D controller
product: GA100 [A100 PCIe 40GB]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:0b:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm cap_list
resources: memory:fc000000-fcffffff memory:e4000000-e5ffffff
also i use ubuntu 22.04 on vmware and i installed latest driver.
$dkms status
nvidia/535.86.05, 5.19.0-1027-oracle, x86_64: installed`
