'nvidia-smi' outputs 'no devices found' Ubuntu 22.04 RTX GeForce 3070 Ti
(Ubuntu 22.04, GeForce RTX 3070 Ti)
Have reinstalled ubuntu 22 fresh.
Do sudo apt-get update && sudo apt-get upgrade -y && sudo apt-get build-essential
Downloaded NVIDIA driver 535 with sudo apt install. (Also did this with runfile previously and didnt work)
Blacklisted nouveau
And nvidia-smi returns “no devices found” or on previous tries has been stuck on executing and never outputs.
202078410bc0a72cb460418a65c546f9.txt (2.3 MB)
Doublecheck your 12 pin power connector is correctly seated and if using 8p->12p adapter, that it’s secure and fully populated with 8pins.
I have a Lambda Tensorbook not a desktop.
I think I need to use an older kernel version. However when I boot into 5.15 it states no wifi adapter found…
A long shot, but looking at the “Additional Information” tab for the latest driver for that GPU at the Nvidia Driver site:
“Some designs incorporating supported GPUs may not be compatible with the NVIDIA Linux driver: in particular, notebook and all-in-one desktop designs with switchable (hybrid) or Optimus graphics will not work if means to disable the integrated graphics in hardware are not available.”
