Ubuntu 20.04 Kernel: 5.14.9-2022-03-19-00 aarch64
NVIDIA GK208B GeForce GT 730
Driver installed via NVIDIA-Linux-aarch64-470.141.03.run
Card model:
Terminal output:
~ ❯ nvidia-smi 03:33:42 PM
[1] 1705 segmentation fault nvidia-smi
Message from syslogd@amore64 at Aug 26 15:34:30 …
kernel:[ 141.254435][ T1705] Internal error: Oops: 96000005 [#1] SMP
kernel:[ 141.314979][ T1705] Code: a9bf7bfd 910003fd b4000100 b40001e1 (79400002)
Grub:
GRUB_CMDLINE_LINUX_DEFAULT=“iommu.passthrough=1”
dmesg:
[ 42.237588] NVRM: loading NVIDIA UNIX aarch64 Kernel Module 470.141.03 Thu Jun 30 18:56:37 UTC 2022
[ 42.250585] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.141.03 Thu Jun 30 18:33:19 UTC 2022
[ 42.255141] [drm] [nvidia-drm] [GPU ID 0x00055800] Loading driver
[ 42.255146] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0005:58:00.0 on minor 1
[ 43.284159] alua: device handler registered
[ 43.303400] emc: device handler registered
[ 43.314883] rdac: device handler registered
[ 45.110697] loop0: detected capacity change from 0 to 8
[ 47.359359] ax88179_178a 4-1.3:1.0 enx00249b16f1f0: ax88179 - Link status is: 1
[ 47.364636] IPv6: ADDRCONF(NETDEV_CHANGE): enx00249b16f1f0: link becomes ready
[ 140.408735] NVRM: failed to register with the ACPI subsystem!
[ 141.254388] Unable to handle kernel access to user memory outside uaccess routines at virtual address 0000000000000010
[ 141.254395] Mem abort info:
[ 141.254397] ESR = 0x96000005
[ 141.254400] EC = 0x25: DABT (current EL), IL = 32 bits
[ 141.254403] SET = 0, FnV = 0
[ 141.254405] EA = 0, S1PTW = 0
[ 141.254408] FSC = 0x05: level 1 translation fault
[ 141.254410] Data abort info:
[ 141.254412] ISV = 0, ISS = 0x00000005
[ 141.254414] CM = 0, WnR = 0
[ 141.254417] user pgtable: 64k pages, 48-bit VAs, pgdp=000000017daca600
[ 141.254421] [0000000000000010] pgd=080000014e270003, p4d=080000014e270003, pud=080000014e270003, pmd=080000014e6c0003, pte=0000000000000000
[ 141.254435] Internal error: Oops: 96000005 [#1] SMP
[ 141.254439] Modules linked in: nf_tables nfnetlink ip6table_filter ip6_tables iptable_filter xt_MASQUERADE iptable_nat nf_nat nf_conntrack binfmt_misc nf_defrag_ipv6 nf_defrag_ipv4 nls_iso8859_1 dm_multipath scsi_dh_rdac sch_fq_codel scsi_dh_emc scsi_dh_alua nvidia_drm(POE) nvidia_modeset(POE) rtl8192cu rtl_usb rtl8192c_common rtlwifi nvidia(POE) joydev cavium_rng_vf input_leds mac80211 thunderx_edac cavium_rng ipmi_ssif libarc4 cfg80211 ipmi_devintf ipmi_msghandler ip_tables x_tables autofs4 btrfs blake2b_generic zstd_compress raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx libcrc32c xor xor_neon raid6_pq raid1 raid0 multipath linear nicvf cavium_ptp ast drm_vram_helper i2c_algo_bit drm_ttm_helper ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops hid_generic cec nicpf crct10dif_ce drm ghash_ce usbhid sha2_ce ahci sha256_arm64 thunder_bgx hid sha1_ce libahci i2c_thunderx thunder_xcv thunderx_mmc mdio_thunder mdio_cavium
[ 141.254610] aes_neon_bs aes_neon_blk aes_ce_blk crypto_simd cryptd aes_ce_cipher
[ 141.254625] CPU: 39 PID: 1705 Comm: nvidia-smi Tainted: P OE 5.14.9-2022-03-19-00 #3
[ 141.254631] Hardware name: GIGABYTE MT30-GS1-00/MT30-GS1-00, BIOS F02 08/06/2019
[ 141.254634] pstate: 40400005 (nZcv daif +PAN -UAO -TCO BTYPE=–)
[ 141.254639] pc : _nv013212rm+0x10/0x50 [nvidia]
[ 141.259349] lr : _nv013205rm+0x1c/0xc8 [nvidia]
[ 141.262431] sp : ffff80002210f380
[ 141.262433] x29: ffff80002210f380 x28: 0000000000000000 x27: ffff000163b2e008
[ 141.262441] x26: ffff0001086b9408 x25: ffff000173d44008 x24: 0000000000000010
[ 141.262449] x23: 0000000000000001 x22: ffff000173d44008 x21: aa0003f4a9025bf5
[ 141.262457] x20: aa0003f4a9025bf5 x19: 0000000000000010 x18: ffff80000d8c28b8
[ 141.262465] x17: ffff80000d8c28c8 x16: ffff80000d8c28d8 x15: ffff80000d8c28e8
[ 141.262473] x14: ffff80000d8c28f8 x13: 000000000000008f x12: ffff80002210f620
[ 141.262481] x11: 0000000000000000 x10: 0000000000000057 x9 : ffff80000d1c0860
[ 141.262488] x8 : 0000000000000005 x7 : 0000000000000058 x6 : 0000000000000010
[ 141.262496] x5 : ffff800080000000 x4 : 000000000000000a x3 : 0000000000000010
[ 141.262503] x2 : 0000000000000001 x1 : aa0003f4a9025bf5 x0 : 0000000000000010
[ 141.262511] Call trace:
[ 141.262514] _nv013212rm+0x10/0x50 [nvidia]
[ 141.265597] _nv013205rm+0x1c/0xc8 [nvidia]
[ 141.268679] _nv013216rm+0x4c/0x230 [nvidia]
[ 141.271761] _nv032995rm+0x20/0xd0 [nvidia]
[ 141.274843] _nv010634rm+0x4c/0x88 [nvidia]
[ 141.277926] _nv031971rm+0x12c/0x958 [nvidia]
[ 141.281009] _nv014424rm+0xe8/0x2b8 [nvidia]
[ 141.284092] _nv014394rm+0x68/0x278 [nvidia]
[ 141.287175] _nv032455rm+0x90/0xb8 [nvidia]
[ 141.290251] _nv013092rm+0x50/0x6d8 [nvidia]
[ 141.293334] _nv022918rm+0xb0/0x1a0 [nvidia]
[ 141.296417] _nv023149rm+0x30/0x80 [nvidia]
[ 141.299500] _nv000672rm+0xe30/0x1aa8 [nvidia]
[ 141.302577] rm_init_adapter+0xb0/0xc0 [nvidia]
[ 141.305654] nv_open_device+0x41c/0x6f8 [nvidia]
[ 141.308736] nvidia_open+0xfc/0x3a0 [nvidia]
[ 141.311819] nvidia_frontend_open+0x70/0xb8 [nvidia]
[ 141.314902] chrdev_open+0xcc/0x250
[ 141.314910] do_dentry_open+0x130/0x398
[ 141.314917] vfs_open+0x30/0x38
[ 141.314922] path_openat+0x8bc/0xf70
[ 141.314927] do_filp_open+0x88/0x110
[ 141.314932] do_sys_openat2+0x214/0x2d0
[ 141.314936] do_sys_open+0x5c/0xa8
[ 141.314941] __arm64_sys_openat+0x28/0x30
[ 141.314946] invoke_syscall+0x48/0x100
[ 141.314953] el0_svc_common+0x4c/0x198
[ 141.314958] do_el0_svc+0x2c/0x90
[ 141.314962] el0_svc+0x20/0x30
[ 141.314968] el0t_64_sync_handler+0xa8/0xb0
[ 141.314972] el0t_64_sync+0x188/0x18c
[ 141.314979] Code: a9bf7bfd 910003fd b4000100 b40001e1 (79400002)
[ 141.314983] —[ end trace c5eaf92012397e26 ]—
[ 141.315203] NVRM: failed to unregister from the ACPI subsystem!
Any hints are appreciated !
