Starting program: /usr/bin/nvidia-settings
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff5996c6a in strlen () from /usr/lib/libc.so.6
(gdb)
my specs:
Arch Linux 64-bit
kernel: 3.13.8-1-ARCH
xorg: 1.15.0-5
xrandr: 1.4.1-1
using primus: 2013 12 26
laptop model: Asus K55VJ-SX069H
graphics: NVIDIA® GeForce with CUDA® 635M 2GB DDR3 VRAM
CPU: INTEL Core i5 Ivy Bridge (3210M)
RAM: 8 GB
At the moment I’m trying to set fan speed trough nvidia-settings because 334.21 driver don’t set it high enough to stop overheating, but when I try to start nvidia-settings in GUI mode (tried trough gksu, sudo, normal user) everything ends up in same SIGSEGV. Of course it works fine on Win8. Could you raise fix your thermal settings in this driver? or just fix this issue to let me do it myself? Thanks in advance.
