I downloaded and used the NVIDIA preview driver 590.26, but there are some problems. Contrary to my expectation that it would work in all games, I confirmed that smooth motion does not work in games such as Sony or EA games and re engine. It seems to be blocked by a specific engine or anti-cheat. Another problem is that when running smooth motion in a game with frame generation function in the 40 series, frame generation is turned off and only smooth motion is running, which causes excessive input lag. I hope it will be fixed in the next driver update. Comments and discussion are welcome!
I’ve tried the beta driver on several games and so far games like Cyberpunk 2077, I’m able to combine and use both Smooth Motion and DLSS or FSR Frame Generation. My fps double!! 302fps in Cyberpunk 2077, God of War Ragnarok, Horizon games,the list goes on. As long as you don’t try to enable Vsync I don’t sense any input lag using the mouse. It’s like getting 4x frame generation for my RTX 4060. Works amazing with MindsEye too!!
Thanks for your reply, did you just use the 590.26 driver update or did you also use the nvidia inspector?
