Hi everyone,
I’m hoping to get some community feedback on an issue I’m facing while deploying the NVIDIA ACE / Tokkio 5.0.0-GA suite on a bare-metal Kubernetes cluster.
The High-Level Goal: We are setting up the full Tokkio stack on Kubernetes to power a digital human, including the Unreal renderer, WebRTC streaming, and the Tokkio UI/API.
The Core Problem: While the base services are running and I can access the Tokkio UI (the NVIDIA logo appears), the streaming session fails to start. The browser’s developer console consistently shows the error: Failed to start inbound stream for VST (VST_INBOUND_STREAM_ERROR)
Diagnosis & Key Findings: After some investigation, I believe this WebRTC error is a symptom of a deeper issue with the backend services. Here’s a summary of what I’ve found:
What’s Working:
The Kubernetes cluster is healthy, and the NVIDIA GPU Operator is running correctly.
Core microservices like
ia-unreal-renderer,vms-vms,riva-speech, andtokkio-uiare deployed and in aRunningstate. -
Firewall rules and NodePorts are configured correctly; I’ve verified with
tcpdumpthat traffic is reaching the host.
Where It Fails:
API Endpoints Return 404: All HTTP requests to the Tokkio API and ACE Configurator endpoints are met with a
404 Not Foundresponse from the OpenResty/Nginx ingress. -
Missing Deployments: My main suspicion is that the
tokkio-apiandstreambridgedeployments are missing or were not enabled during the installation. Runningkubectl get deploymentsseems to confirm their absence. -
Redis Connectivity: Some pods are logging “Waiting for redis,” even though the
redis-timeseriespod and its service are running correctly with a valid endpoint.
My Current Theory: The VST_INBOUND_STREAM_ERROR occurs because the Tokkio UI cannot communicate with the necessary backend APIs (tokkio-api, streambridge) to complete the WebRTC handshake. These APIs appear to be not deployed, which is why the ingress controller returns a 404.
My Question for the Community: Has anyone encountered a similar situation where the tokkio-api or streambridge services don’t deploy by default with the standard charts/manifests? Are there specific configuration values I should double-check to ensure these critical components are enabled and correctly routed by the ingress?
Any guidance or suggestions would be greatly appreciated. I’m happy to provide more detailed logs or configs if needed.
Thanks in advance for your help!
