I changed forced full composition option to checked to solve screen tearing problem. But if i change this setting, nvidia x server generates xorg.conf file and this file disables my second monitor. if i delete xorg and reboot everything solved without force composition. now attached xorg information is forced composition checked and second montior does not recognized. Asus is my external monitor and my built in monitor is hp pavilion 1bv33ea laptops monitor → this goes right after creating xconf. So how can i add my other monitor to this xorg file manually with forced compositon on option for both displays?
OS: Ubuntu 20.04
GPU: GTX960m + intel hd graphics 530
Displays: HP 1BV33EA Laptop + ASUS VP228
xrandr
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 16384 x 16384
HDMI-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 476mm x 268mm
eDP-1-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
My xorg file i think there is no description for second display:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 440.82
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "AUS ASUS VP228"
HorizSync 24.0 - 83.0
VertRefresh 48.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 960M"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "1920x1080_75 +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
