GPU
• DeepStream Version
6.1.1
• TensorRT Version
I am trying to to deploy an amp trained onnx model to DS in fp16 mode. Some of the layers (specifically the conv layers), require fp32 precision, since TRT will clamp the weights to 1e-7 (fp16 min) causing faulting results:
It should be possible to avoid this, by settinglayer-device-precision=/beit/embeddings/patch_embeddings/projection/Conv:fp32:gpu
in the configuration file - however this seems to not work.
Do you have any suggestions as to how I can avoid casting the conv layers to FP16 and run the model in mixed precision?
ONNX model link: https://file.io/qvvjn27luBkt and config file is attached for reference.
beit-base-patch16-224-pt22k-ft22k.config (648 Bytes)
