Hi Nvidia,
We are using a 64GB AGX Orin without EEPROM on the carrier board. During flashing, modify the following file
Linux_for_Tegra/bootloader/tegra234-mb2-bct-common.dtsi
1.Flashing to eMMC works normally with the following command:
sudo ./flash.sh jetson-agx-orin-devkit internal
2.Flashing to NVMe fails with the following command:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml \
--showlogs --network usb0 jetson-agx-orin-devkit external
Error message:
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Key issues observed:
- The flashing process times out during “Waiting for target to boot-up…”
- Device fails to boot to the initrd flash kernel
- Error suggests the no-flash flag is enabled
full log
flash_external_log.txt (269.4 KB)
Hi norman_xu,
Please try using the following command instead.
$ sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit internal
Hi KevinFFF,
Unfortunately, the issue still persists.
flash log:
flash_log.txt (263.6 KB)
You are purposely using Jetpack 6.0 with kernel 5.15.136-tegra?
The --no-flash part of your log is from when Jetpack first flashes bootloader/generic/cfg/flash_t234_qspi.xml and is not an error.
If you use the same usb port on your x86_64 host then this may work.
cat /sys/bus/usb/devices/1-2/power/control
if it isn’t ‘on’ then
echo on | sudo tee /sys/bus/usb/devices/1-2/power/control
so your host usb doesn’t sleep. Then
cd /home/fyx/xxs/Linux_for_Tegra
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-2 --device-instance 0 --flash-only --external-device nvme0n1p1-c "./tools/kernel_flash/flash_l4t_t234_nvme.xml" jetson-agx-orin-devkit internal
Hi whitesscott,
Yes, Jetpack 6.0 ( R36.3.0)
flash error log:
flash_log.txt (66.6 KB)
Here’s another method that might work
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" \
./flash.sh -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml \
jetson-agx-orin-devkit nvme0n1p1
Hi whitesscott,
A different error appeared while flashing with this command.
[ 2.2954 ] Packing sdram param for instance[10]
[ 2.2954 ] Packing sdram param for instance[11]
[ 2.2955 ] Packing sdram param for instance[12]
[ 2.2955 ] Packing sdram param for instance[13]
[ 2.2956 ] Packing sdram param for instance[14]
[ 2.2957 ] Packing sdram param for instance[15]
[ 2.3562 ] Reading ramcode from backup chip_info.bin file
[ 2.3562 ] RAMCODE Read from Device: 3
[ 2.3562 ] Using ramcode 0
[ 2.3562 ] Disabled BPMP dtb trim, using default dtb
[ 2.3562 ]
[ 2.3566 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 2.3572 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 2.3573 ] adding BCH for mem_rcm_aligned.bct
[ 2.3595 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.3596 ] Assuming zero filled SBK key
[ 2.3606 ] Warning: pub_key.key is not found
[ 2.3605 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 2.3614 ] Copying signatures
[ 2.3617 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
File "/home/fyx/xxs/Linux_for_Tegra/bootloader/./tegraflash.py", line 1456, in <module>
tegraflash_run_commands()
File "/home/fyx/xxs/Linux_for_Tegra/bootloader/./tegraflash.py", line 1276, in tegraflash_run_commands
interpreter.onecmd(command)
File "/usr/lib/python3.10/cmd.py", line 217, in onecmd
return func(arg)
File "/home/fyx/xxs/Linux_for_Tegra/bootloader/./tegraflash.py", line 289, in do_flash
self.chip_inst.tegraflash_flash(exports)
File "/home/fyx/xxs/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py", line 979, in tegraflash_flash
self.tegraflash_send_to_bootrom()
File "/home/fyx/xxs/Linux_for_Tegra/bootloader/tegraflash_impl_t234.py", line 1013, in tegraflash_send_to_bootrom
info_print(mb1_bin + " filename is from images_list")
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
Failed flashing generic.
full log:
flash_log.txt (50.2 KB)
If your Linux_for_Tegra was created via manually downloaded Jetson_Linux_r36.3.?_aarch64.tbz2 and Tegra_Linux_Sample-Root-Filesystem_r36.3.?_aarch64.tbz2 then it may help to run following if you haven’t already.
If you have changed your ./rootfs directory back it up first to be safe.
sudo ./apply_binaries.sh
sudo ./tools/l4t_flash_prerequisites.sh
then try this again
From the flash log your shared, it seems failing at Step 3: Start the flashing proces to wait the board boot up.
Please share the full serial console log at this moment for further check.
Hi FevinFFF,
the full serial console log:
minicom_log.txt (76.2 KB)
After replacing the DTB file, the issue has been resolved. Thanks.
