Jetson AGX Orin flashing issue
I want to flashing the agx orin by flash command,but it also fail. I have no idea how to solve the problem. I need your help,thank you!
flashing command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p “-c ./bootloader/generic/cfg/flash_t234_qspi.xml” -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit internal
console log
L4TLauncher: Attempting RCM Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (gts@gts-T14-Gen-3) (aarch64-buildroot-linux-gnu-gcc.br_real (Bu)
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: TPMFinalLog=0xfeecd0000 SMBIOS=0xffff0000 SMBIOS 3.0=0xffdc00000 MEMATTR=0xffa0ba018 TPM
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000100c000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1004c54800-0x1004c56fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000feec64fff]
[ 0.000000] node 0: [mem 0x0000000feec65000-0x0000000feecdffff]
[ 0.000000] node 0: [mem 0x0000000feece0000-0x0000000ffc1cffff]
[ 0.000000] node 0: [mem 0x0000000ffc1d0000-0x0000000ffe10ffff]
[ 0.000000] node 0: [mem 0x0000000ffe110000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
[ 0.000000] node 0: [mem 0x000000102d700000-0x000000102d7fffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On ��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
��node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in fir��WARNING: clock_disable: clk_power_ungate on gated domain 35 fk
��mware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU fe��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��atures: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16187760
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 fie
��class.path=/etc/firmware fbcon=map:0 net.ifnames=0 bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=6.
��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla1_core
��[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla1_falcon
��IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 63783060K/65780160K available (19840K kernel code, 4434K rwdata, 10668K rodata, 8320K)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObje��WARNING: clock_disable: clk_power_ungate on gated domain
��cts=0, CPUs=12, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_core
��.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafe
��for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Di��WARNING: clock_disable: clk_power_ungate on gated domain 34 for dla0_falcon
��stributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ ��WARNING: clock_disable: clk_power_ungate on gated domain 34 for nafll_dla0_falcon
�� 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 88s
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000549] Console: colour dummy device 80x25
[ 0.000691] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lp)
[ 0.000706] pid_max: default: 32768 minimum: 301
[ 0.000769] LSM: Security Framework initializing
[ 0.000811] Yama: becoming mindful.
[ 0.000843] SELinux: Initializing.
[ 0.001245] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001546] Mountpoint-cache hash table entries: 131072 (order: 8, 10��WARNING @ [platform/drivers/clk/cl4
��48576 bytes, linear)
[ 0.004811] rcu: Hierarchical SRCU implementation.
[ 0.009610] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[ 0.009983] Remapping and enabling EFI services.
[ 0.011173] smp: Bringing up secondary CPUs …
[ 0.012058] Detected PIPT I-cache on CPU1
[ 0.012160] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.012241] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.012985] Detected PIPT I-cache on CPU2
[ 0.013000] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.013022] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.013681] Detected PIPT I-cache on CPU3
[ 0.013694] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.013713] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.016415] Detected PIPT I-cache on CPU4
[ 0.016442] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.016469] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.017178] Detected PIPT I-cache on CPU5
[ 0.017190] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.017206] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.017888] Detected PIPT I-cache on CPU6
[ 0.017900] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.017919] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.018591] Detected PIPT I-cache on CPU7
[ 0.018603] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.018621] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
8-t 0.02135mod /lib/ectmodPIPT I-caule.15 on CP.14U8
a/u 0tes.02/drGICv3:ivers/netU8: fo/et redisnet/realtek/or 00 68/r81ion68.ko 000
probe: ERROR00f: c000
ould n 0ins141 ‘r8168’: ExCPUformat er8: tedror secondary processor 0x0000020ena [0blex41mot0fdcce421ss
[ 0ena re212e aDetcceed PIPT I-cache on CPU9
[ 0.022135] GICins /lib/ CPU9:s/5.15und re.148-ttributor a/k201regernel/ 0:drivers/p000560hy/ra/phy-te
0gra194-p2.02215u.k6] o CPUmodprotedbe: ERROR: could not insrocesshy_0x0ra194_p2u100x41’: Exe421ormat erro6
2] Detected PIPT I-camod /l onib/ules/5.15
8-tegra/kern287el/GICdriv3:U10s/p: fci/troounllewc/pcie-tegra19edistro tor
s/nvme 0/host/.02nvm356e-cDetore ed 'p000f58_te000gra[ 194 0Exe.02c format err7] or10: Booted secondary p]
PIPpro-cache ER onU11RORould not 0357ins 'n4] ': v3:c format : ferround redistributor 20300mod /lib/gioule0
ern 0dri.02ver3593] CPUmal/te Bograd s/tegrary mp-prormal.kcessor
d n[ 0ert 't366egrpmpsmp: B_thal’ght: Exec up forma 1 nodrro12 rCPUs
[ 0.023676] ins /l: Tib/uleotal os/5.148-tf 1egr2 pa/krocesserndrivers/ptivatewm/pwm
[ gra.ko 0
368modbe: ERROR: could nCPUot insert ‘pwm_tegra’etected: xec32-rmabitt eupprroort
r[
0.023684] CPU featuresinsetemodctemoduleData c.14ache c8-tn tegro the a/kern nodriverequired fwmoI/Dn/pwm-
.02modpro368be:8] ROR: cCPU feoulatu: deteot cteinsd: ‘pwm_monfan’: Exec ft Pormateat trerranslation
s
[ 0.023690] ins femodaturesib/mod: ds/5.15ete.148-tcteegrCRCa/k32 insel/vertructis/u
sb/gad[ 0.02bco3691] CPU femporessitetecteo d: moda cachproe c ERleaRORo P: ct ooulot f Pinsence
‘l[ omp 0osite’.02: Exec fo5] CPUt e ferrorresete
d: Generic authenticatioinsmod /larchitib/ectmoded algulethm)
s/5[ .15.02.14CPU featuresegra/k: deteerncted: el/driRCpveroads/u-acec/typec.re (LDAPR
[ 0.02be: ER369RORCPUatuould not : dinscteertd: atypec inst Exructions
format[ 0 er.02ror3699] CPU features: deteins /ld: Priib/ulevileges/5d Acceegrss a/kel/dri
ver[ s/u 0.02e
cted: mod Exbe: ERtensioROR: couln Sd not insert
0.02csi3704] g’:CPU fe Exec atuformat: deterorcted: Speculative StoinsmodBypassib/ingmodfe (SSBS)
.15[ 8-t 0egr.07ern922dri3] verCPU: Asb/gadget/udll (s) stc/ta-xudcart.koat
0
.08modpro7553] devtmpROR: c initioulaliot zedert ‘t[ 0a_x’: Exe.11105ormat KASLR orenabled
[ 0.111259] cloinsmodcks /lib/modce:s/5 ji.15ffies:8-tegrsk:ern 0xfffel/fffff maxnet_cy/ips: v6/0xffff6.k:
76450be:85100000 ns
ROR[ 0oul.11ot ert128 ‘ifutpv6’: h tablc forme eat orntries: 4
(order: 6, 262144 byins /l, lib/ar)mod
ule[ 0.120740] pin.14l c8-tegr: initpdatesize/drd pincrs/nvpps/ sups.ko bsy
m
mod 0.12181be:2] SMBIOS 3.: c6.0ot ins prnt.
‘n[ 0vet182her2] DMI: N’: IA NVIExec f Jeormtson Aerrorn D
loper Kit/Jetson, BIOS 36.4ins /lgciib/1062509 06/16/2ules/5.15
.14[ 8-t.122406] NET: Regrstered PFa/kernel/dri_NENK/verROUTE s/usb/typec/prool family
ec. 0.12482
0] mod: preabe:cat ERed ROR8192 Kot insert 's_KERNEtusL poolb16 fo0x’tomic : Eallocaxec fotions
t error[ .12
5506] DMA: prealloinsmod /l2 Kib/iB GFPule_KEs/5L|G.14FP_DMAegra/updatesol for at/drc alloiveions
pla[ tfo 0tegra/mce.123] /te: pgrallocated 8192 KiB GFP_KEe.ko FP
probe: ERl for : coul alot insationsert 'tegra_m[ : Exec.12623 fo0] audit: inrroitirzing netl
subsys (disabled)
insmod /lib/636mod7] audit: tyules/5.15200.140 a8-tegr.12): a/ustate=inites/drlizivers/audit_enablespid=0 re1
egr[ 0.12a218450] uad.kotherma l_s
ys: Regisbe:tered ERthel gROR: coulovernor ‘ot insise’
ert 0.12845pi_9] tegra2l_sys: Regisquaed the Exforrmamat errorl governor ‘user_space’
[ 0.128463] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.133598] cpuidle: using governor menu
[ 0.133768] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.133932] ASID allocator initialised with 32768 entries
[ 0.136108] Serial: AMBA PL011 UART driver
[ 0.146481] tegra-mc 2c00000.memory-controller: unknown: write @0x00000000500605d0: Security violation (T)
[ 0.147413] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.158269] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.167093] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.167100] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.167101] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.167104] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.168216] cryptd: max_cpu_qlen set to 1000
[ 0.170074] ACPI: Interpreter disabled.
[ 0.171962] iommu: Default domain type: Translated
[ 0.171969] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.172320] SCSI subsystem initialized
[ 0.172496] vgaarb: loaded
[ 0.172649] usbcore: registered new interface driver usbfs
[ 0.172678] usbcore: registered new interface driver hub
[ 0.172700] usbcore: registered new device driver usb
[ 0.173149] pps_core: LinuxPPS API ver. 1 registered
[ 0.173156] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.173173] PTP clock support registered
[ 0.173251] EDAC MC: Ver: 3.0.0
[ 0.174537] Registered efivars operations
[ 0.175044] FPGA manager framework
[ 0.175128] Advanced Linux Sound Architecture Driver Initialized.
[ 0.175625] Bluetooth: Core ver 2.22
[ 0.175652] NET: Registered PF_BLUETOOTH protocol family
[ 0.175657] Bluetooth: HCI device and connection manager initialized
[ 0.175668] Bluetooth: HCI socket layer initialized
[ 0.175674] Bluetooth: L2CAP socket layer initialized
[ 0.175694] Bluetooth: SCO socket layer initialized
[ 0.176048] clocksource: Switched to clocksource arch_sys_counter
[ 0.213565] VFS: Disk quotas dquot_6.6.0
[ 0.213645] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.213901] pnp: PnP ACPI: disabled
[ 0.217388] NET: Registered PF_INET protocol family
[ 0.218017] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.220235] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.220951] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.220998] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.221383] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.222688] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.222948] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.223062] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.223383] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.223892] RPC: Registered named UNIX socket transport module.
[ 0.223897] RPC: Registered udp transport module.
[ 0.223897] RPC: Registered tcp transport module.
[ 0.223899] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.223916] PCI: CLS 0 bytes, default 64
[ 0.224140] Unpacking initramfs…
[ 0.233698] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.234067] kvm [1]: IPA Size Limit: 48 bits
[ 0.234106] kvm [1]: GICv3: no GICV resource entry
[ 0.234113] kvm [1]: disabling GICv2 emulation
[ 0.234142] kvm [1]: GIC system register CPU interface enabled
[ 0.234273] kvm [1]: vgic interrupt IRQ9
[ 0.234493] kvm [1]: VHE mode initialized successfully
[ 0.237811] Initialise system trusted keyrings
[ 0.237853] Key type blacklist registered
[ 0.237988] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[ 0.241866] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.242256] NFS: Registering the id_resolver key type
[ 0.242275] Key type id_resolver registered
[ 0.242279] Key type id_legacy registered
[ 0.242336] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.242352] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.242378] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.242631] 9p: Installing v9fs 9p2000 file system support
[ 0.243309] integrity: Platform Keyring initialized
[ 0.253693] Key type asymmetric registered
[ 0.253698] Asymmetric key parser ‘x509’ registered
[ 0.253825] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.253833] io scheduler mq-deadline registered
[ 0.253841] io scheduler kyber registered
[ 0.264730] EINJ: ACPI disabled.
[ 0.277040] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.278901] SuperH (H)SCI(F) driver initialized
[ 0.279256] msm_serial: driver initialized
[ 0.279845] printk: console [ttyTCU0] enabled
[ 0.280749] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.280754] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.280763] arm-smmu 8000000.iommu: stage 1 translation
[ 0.280768] arm-smmu 8000000.iommu: stage 2 translation
[ 0.280768] arm-smmu 8000000.iommu: nested translation
[ 0.280773] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.280777] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.280791] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.280794] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.280795] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.281783] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.281786] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.281789] arm-smmu 10000000.iommu: stage 1 translation
[ 0.281791] arm-smmu 10000000.iommu: stage 2 translation
[ 0.281792] arm-smmu 10000000.iommu: nested translation
[ 0.281795] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.281798] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.281803] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.281804] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.281805] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.282172] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.282175] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.282176] arm-smmu 12000000.iommu: stage 1 translation
[ 0.282177] arm-smmu 12000000.iommu: stage 2 translation
[ 0.282177] arm-smmu 12000000.iommu: nested translation
[ 0.282180] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.282182] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.282188] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.282189] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.282190] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.293023] loop: module loaded
[ 0.293904] megasas: 07.717.02.00-rc1
[ 0.298070] tun: Universal TUN/TAP device driver, 1.6
[ 0.298623] thunder_xcv, ver 1.0
[ 0.298647] thunder_bgx, ver 1.0
[ 0.298672] nicpf, ver 1.0
[ 0.299578] hclge is initializing
[ 0.299607] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.299612] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.299654] e1000: Intel(R) PRO/1000 Network Driver
[ 0.299660] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.299688] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.299694] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.299721] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.299727] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.299746] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.299754] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.299996] sky2: driver version 1.30
[ 0.300709] VFIO - User Level meta-driver version: 0.3
[ 0.302158] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.302196] ehci-pci: EHCI PCI platform driver
[ 0.302218] ehci-platform: EHCI generic platform driver
[ 0.302313] ehci-orion: EHCI orion driver
[ 0.302376] ehci-exynos: EHCI Exynos driver
[ 0.302434] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.302452] ohci-pci: OHCI PCI platform driver
[ 0.302481] ohci-platform: OHCI generic platform driver
[ 0.302560] ohci-exynos: OHCI Exynos driver
[ 0.303001] usbcore: registered new interface driver usb-storage
[ 0.305064] i2c_dev: i2c /dev entries driver
[ 0.306433] pps pps0: new PPS source ktimer
[ 0.306441] pps pps0: ktimer PPS source registered
[ 0.306447] pps_ldisc: PPS line discipline registered
[ 0.308601] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.310433] sdhci: Secure Digital Host Controller Interface driver
[ 0.310438] sdhci: Copyright(c) Pierre Ossman
[ 0.310904] Synopsys Designware Multimedia Card Interface Driver
[ 0.311549] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.313279] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.314106] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.314663] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.316056] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[ 0.675519] Freeing initrd memory: 33664K
[ 3.922873] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 3.922894] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 3.922899] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 3.923098] hid: raw HID events driver (C) Jiri Kosina
[ 3.923467] usbcore: registered new interface driver usbhid
[ 3.923473] usbhid: USB HID core driver
[ 3.928453] optee: probing for conduit method.
[ 3.928513] optee: revision 4.2 (d78bc5fa)
[ 3.987647] optee: dynamic shared memory is enabled
[ 3.987900] optee: initialized driver
[ 3.990503] usbcore: registered new interface driver snd-usb-audio
[ 3.991928] NET: Registered PF_PACKET protocol family
[ 3.992540] Bluetooth: RFCOMM TTY layer initialized
[ 3.992550] Bluetooth: RFCOMM socket layer initialized
[ 3.992577] Bluetooth: RFCOMM ver 1.11
[ 3.992751] 9pnet: Installing 9P2000 support
[ 3.992848] Key type dns_resolver registered
[ 3.993606] printk: console [ttyTCU0]: printing thread started
[ 3.993679] Loading compiled-in X.509 certificates
[ 4.026491] gpio-394 (camera-control-output-low): hogged as output/low
[ 4.026517] gpio-397 (camera-control-output-low): hogged as output/low
[ 4.026542] gpio-487 (camera-control-output-low): hogged as output/low
[ 4.026560] gpio-486 (camera-control-output-low): hogged as output/low
[ 4.031962] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.034344] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 4.036725] serial-tegra 3100000.serial: RX in PIO mode
[ 4.036733] serial-tegra 3100000.serial: TX in PIO mode
[ 4.036845] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 4.038454] serial-tegra 3110000.serial: RX in PIO mode
[ 4.038458] serial-tegra 3110000.serial: TX in PIO mode
[ 4.038541] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 207, base_baud = 0) is a TEGRA_UART
[ 4.042920] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.042929] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.043470] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.051926] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.057956] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 4.063688] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.069279] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 4.075145] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 4.081677] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.087842] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.122882] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing tz
[ 4.125995] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing tz
[ 4.129095] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 4.130061] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 4.131222] irq: IRQ234: trimming hierarchy from :bus@0:pmc@c360000
[ 4.131288] irq: IRQ235: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.131329] irq: IRQ236: trimming hierarchy from :bus@0:pmc@c360000
[ 4.131387] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.627288] ALSA device list:
[ 4.627293] No soundcards found.
[ 4.630125] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 4.641371] mmc0: CQHCI version 5.10
[ 4.677367] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 4.678727] irq: IRQ237: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.679363] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 4.680288] Freeing unused kernel memory: 8320K
[ 4.680378] Run /init as init process
[ 4.694722] Root device found: initrd
[ 4.708291] r8168: disagrees about version of symbol module_layout
[ 4.714924] Mount initrd as rootfs and enter recovery mode
[ 4.735783] phy_tegra194_p2u: disagrees about version of symbol module_layout
[ 4.754164] pcie_tegra194: disagrees about version of symbol module_layout
[ 4.772038] nvme_core: disagrees about version of symbol module_layout
[ 4.785916] mmc0: Command Queue Engine enabled
[ 4.785923] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.786149] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[ 4.789935] tegra_bpmp_thermal: disagrees about version of symbol module_layout
[ 4.793930] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 4.794599] mmcblk0boot0: mmc0:0001 DG4064 4.00 MiB
[ 4.795030] mmcblk0boot1: mmc0:0001 DG4064 4.00 MiB
[ 4.795413] mmcblk0rpmb: mmc0:0001 DG4064 4.00 MiB, chardev (511:0)
[ 4.808750] pwm_tegra: disagrees about version of symbol module_layout
[ 4.827822] pwm_fan: disagrees about version of symbol module_layout
[ 4.849189] libcomposite: disagrees about version of symbol module_layout
[ 4.872379] typec: disagrees about version of symbol module_layout
[ 4.891443] typec: disagrees about version of symbol module_layout
[ 4.912186] tegra_xudc: disagrees about version of symbol module_layout
[ 4.931518] ipv6: disagrees about version of symbol module_layout
[ 4.950324] nvpps: disagrees about version of symbol module_layout
[ 4.975183] typec: disagrees about version of symbol module_layout
[ 4.999594] tegra_mce: disagrees about version of symbol module_layout
[ 5.024274] spi_tegra210_quad: disagrees about version of symbol module_layout
Connection timeout: device /dev/nvme0n1 is still not ready.
[ 35.808237] VDD_3V3_PCIE: disabling
[ 35.808254] VDD_12V_PCIE: disabling
No known UDC device found
[ 76.129006] ipv6: disagrees about version of symbol module_layout
[ 76.135679] ipv6: disagrees about version of symbol module_layout
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1#
flashing log
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/bootloader /home/gts/agx_orin_36.4.4/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/gts/agx_orin_36.4.4/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3737-0000+p3701-0005-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --instance 3-1 --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3737-0000+p3701-0005-nv.dtb"    --bct_backup
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_internal.py:1273: SyntaxWarning: invalid escape sequence '\.'
  patt = re.compile(".*(mbr|gpt).*\.bin")
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_internal.py:1389: SyntaxWarning: invalid escape sequence '\.'
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_internal.py:4589: SyntaxWarning: invalid escape sequence '\s'
  m = re.search('bpmp_fw_dtb[\s]+([\w._-]+)', values['--bins'])
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegrasign_v3_internal.py:1142: SyntaxWarning: invalid escape sequence '\d'
  m = re.search('Key size is (\d+)', ret_str)
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegrasign_v3_internal.py:1188: SyntaxWarning: invalid escape sequence '\d'
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegrasign_v3_internal.py:1546: SyntaxWarning: invalid escape sequence '\d'
  re_string = 'kdf_args_' + temp_stem + '(\d).yaml'
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_impl_t234.py:1565: SyntaxWarning: invalid escape sequence '\s'
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_impl_t234.py:3090: SyntaxWarning: invalid escape sequence '\.'
/home/gts/agx_orin_36.4.4/Linux_for_Tegra/temp_initrdflash/bootloader0/tegraflash_impl_t234.py:3151: SyntaxWarning: invalid escape sequence '\/'
  info_print("Copying enc\/signed file in " + output_dir)
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0229 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0229 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0229 ] rcm boot with presigned binaries
[   0.0233 ] tegrarcm_v2 --instance 3-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0236 ] BR_CID: 0x80012344705E01485C00000003000100
[   0.0339 ] Sending bct_br
[   0.0431 ] Sending mb1
[   0.0435 ] Sending psc_bl1
[   0.0567 ] Sending bct_mb1
[   0.0640 ] Generating blob for T23x
[   0.0654 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0657 ] The number of images in blob is 19
[   0.0661 ] blobsize is 101773318
[   0.0662 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2158656
[   0.1018 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.1021 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.1022 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.1023 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[   0.1024 ] Not supported type: mb2_applet
[   0.1025 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[   0.1026 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1027 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.1034 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12075728
[   0.1084 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1109 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1114 ] Added binary blob_tegra234-bpmp-3701-0005-3737-0000_with_odm_sigheader.dtb.encrypt of size 265024
[   0.1117 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1120 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[   0.1121 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1125 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[   0.1134 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1136 ] Added binary blob_boot0.img of size 78931968
[   0.1513 ] Added binary blob_tegra234-p3737-0000+p3701-0005-nv.dtb of size 254662
[   0.2060 ] tegrarcm_v2 --instance 3-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.2064 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.3318 ] Sending bct_mem
[   0.3496 ] Sending blob
[   4.3234 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
The provided console log is from a Jetson AGX Orin Developer Kit, and it appears to be a boot log. The log shows the system booting up, initializing various components, and loading drivers.
The flashing command used is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit external
This command is used to flash the Jetson AGX Orin Developer Kit with a new image. The --external-device option specifies the device to flash, which in this case is an NVMe device (nvme0n1p1). The -p option specifies the configuration file for the bootloader, and the -c option specifies the configuration file for the flash process.
The log shows that the system is booting up, and various components are being initialized, including the CPU, memory, and I/O devices. The log also shows that the system is loading various drivers, including the NVMe driver, the USB driver, and the network driver.
However, the log also shows several error messages, including:
WARNING: clockdisable clkpowerungate on gated domain 34 for dla0core
WARNING: clockdisable clkpowerungate on gated domain 34 for dla1core
WARNING: clockdisable clkpowerungate on gated domain 34 for naflldla0core
WARNING: clockdisable clkpowerungate on gated domain 34 for naflldla1core
These error messages indicate that there are issues with the clock and power management on the system.
Additionally, the log shows that there are several modules that are disagreeing about the version of the modulelayout symbol, including:
r8168 disagrees about version of symbol modulelayout
phytegra194p2u disagrees about version of symbol modulelayout
pcietegra194 disagrees about version of symbol modulelayout
nvmecore disagrees about version of symbol modulelayout
This could indicate that there are compatibility issues between the kernel and the modules.
Finally, the log shows that the system is unable to find a UDC device, and that there is a connection timeout:
Connection timeout device devnvme0n1 is still not ready
This could indicate that there are issues with the NVMe device or the connection to it.
Overall, the log suggests that there are several issues with the system, including clock and power management issues, compatibility issues between the kernel and modules, and issues with the NVMe device. These issues may need to be addressed in order to successfully flash the system.
In comparison to the other flashing commands provided, this command is similar to the one used for the Jetson AGX Orin series with NVMe as the rootfs storage:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -u <pkc_keyfile> [-v <sbk_keyfile>] --uefi-keys uefi_keys/uefi_keys.conf -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit external
However, this command includes additional options, such as the -u and -v options, which specify the PKC and SBK key files, respectively. The --uefi-keys option specifies the UEFI key file.
In contrast, the flashing command for the Jetson AGX Orin series with eMMC as the rootfs storage is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -u <pkc_keyfile> [-v <sbk_keyfile>] --uefi-keys uefi_keys/uefi_keys.conf jetson-agx-orin-devkit internal
This command is simpler and does not include the --external-device option, as eMMC is the default storage device for this system.
Some questions to confirm:
  • Are you using a developer kit or a custom board for your AGX Orin?
  • Does your AGX Orin have an NVMe drive installed?
I use AGX Orin Developer Kit 64G, and it has 1T NVMe. It can flash sucess to nvme using JetPack_6.2.1. But the command can not flash success.
How did you flash it successfully? Did you flash it successfully using SDK Manager?
What’s JetPack version you are using?
The sdkmanager version is 2.4.0.13235, select storage device is nvme, it can flash to nvme ssd success.
截图 2026-04-16 08-27-20
But I use the below command it can not flash success. The log to see comment 1#
Please try below commands as developer guide show
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
