- Docker image:
nvcr.io/nvidia/deepstream:5.0-dp-20.04-samples - API: gst-python + pyds
- Hardware: nvidia-smi output =
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| 0 GeForce GTX 1660 Off | 00000000:1E:00.0 Off | N/A |
| 29% 32C P8 9W / 120W | 160MiB / 5944MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
I have a pipeline like this:
srcs -> nvstreammux -> nvinfer -> nvtracker -> nvvideoconvert(1) -> capsfilter(1) -> nvmultistreamtiler -> nvvideoconvert(2) -> nvdsosd -> tee -> sinks
- When capsfilter(1) is set to
"video/x-raw(memory:NVMM),format=RGBA"- setting tiler
show-sourceto any value != -1 makes the display black instead of showing the respective source. - setting tiler
show-sourceback to -1 then all sources are tiled and displayed normally.
- setting tiler
- When capsfilter(1) is left empty, then tiler
show-sourceworks as expected but the problem is that in this case images can’t be extracted from buffer probe on nvvideoconvert(1), becausepyds.get_nvds_buf_surfaceworks only with RGBA.
