Nvoglv32.dll causing app crashes for all programs running opengl
When I try to run evidently any program that’s actively utilizing OpenGL, I run into startup crashes or immediate freezes upon changing renderers.
msinfo32 output:
OS Name Microsoft Windows 11 Enterprise
Version 10.0.22631 Build 22631
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name PW01N19W
System Manufacturer LENOVO
System Model 20Y4S17D00
System Type x64-based PC
System SKU LENOVO_MT_20Y4_BU_Think_FM_ThinkPad P1 Gen 4i
Processor 11th Gen Intel(R) Core™ i9-11950H @ 2.60GHz, 2611 Mhz, 8 Core(s), 16 Logical Processor(s)
GPU is Geforce RTX 3080 on Game Ready 551.61 drivers.
Example output from Windows Event Viewer:
----------START OUTPUT----------
Log Name: Application
Source: Application Error
Date: 2/23/2024 9:13:45 AM
Event ID: 1000
Task Category: Application Crashing Events
Level: Error
Keywords:
User: AzureAD[redacted]
Computer: PW01N19W
Description:
Faulting application name: Zortch.exe, version: 0.0.0.0, time stamp: 0x65cf70b7
Faulting module name: nvoglv32.dll, version: 31.0.15.5123, time stamp: 0x65a8bf93
Exception code: 0xc0000005
Fault offset: 0x00caa556
Faulting process id: 0x0x5344
Faulting application start time: 0x0x1DA666AE42D0B9A
Faulting application path: C:\Program Files (x86)\Steam\steamapps\common\Zortch\Zortch.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\nvltig.inf_amd64_60796aa09a3d57d6\nvoglv32.dll
Report Id: 8ba3bbb4-10df-4c43-a561-dec86574437e
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns=“http://schemas.microsoft.com/win/2004/08/events/event”>
1000
0
2
100
0
0x8000000000000000
44708
Application
PW01N19W
Zortch.exe
0.0.0.0
65cf70b7
nvoglv32.dll
31.0.15.5123
65a8bf93
c0000005
00caa556
0x5344
0x1da666ae42d0b9a
Date: 2/23/2024 9:23:07 AM
Event ID: 1000
Level: Error
Keywords:
Computer: PW01N19W
Description:
Faulting application name: hl.exe, version: 1.1.1.1, time stamp: 0x6585ef9d
Faulting process id: 0x0x382C
Faulting application start time: 0x0x1DA666C2B0C3311
Faulting application path: C:\Program Files (x86)\Steam\steamapps\common\Half-Life\hl.exe
Report Id: 50f9d873-9d72-4fce-a1a5-254b3954aee8
Event Xml:
1000
0
2
100
0
0x8000000000000000
44717
Application
PW01N19W
hl.exe
1.1.1.1
6585ef9d
nvoglv32.dll
31.0.15.5123
65a8bf93
c0000005
00caa556
0x382c
0x1da666c2b0c3311
----------END OUTPUT----------
Booted into safe mode to run DDU, then ran clean install of latest Nvidia drivers but no luck, still getting app error due to module nvoglv32.dll. When I disable the Nvidia adapter via devmgmt.msc, then these programs run without issue.
i have the exact problem about nvoglv32.dll >> opengl
i dont understand but i bought 4070ti, a few months later this problem started. i tried many different drivers but couldnt get any solution. im writing from a pc where i freshly ddu’d then installed latest drivers.
Faulting application name: Path of Building.exe, version: 0.0.0.0, time stamp: 0x606d1b4c
Faulting module name: nvoglv32.dll, version: 31.0.15.5161, time stamp: 0x65cded26
Fault offset: 0x00cae7e6
Faulting process id: 0x778
Faulting application start time: 0x01da6a7916557377
Faulting application path: C:\Users\emre\AppData\Roaming\Path of Building Community - Copy\Path of Building.exe
Faulting module path: C:\Windows\System32\DriverStore\FileRepository\nvmdig.inf_amd64_f2364b8cd60b763b\nvoglv32.dll
Report Id: 7bc12ed9-98e2-4275-aacf-263f10465c31
kenneth.gant, Thanks for reporting this. Is this still reproducing on latest web driver? See 552.44 from
Wen
Wen, I am having a similar issue as Kenneth. Mine device has an NVIDIA 1050 Ti Max-Q laptop GPU. Is this a Ti-related issue?
As troubleshooting steps, I did a complete uninstall of the device driver (from the Windows 10 Device Manager), including file deletion; then I re-installed the latest driver (552.44, reported in Windows as 31.0.15.5244) through GeForce Experience as a clean installation. The problem still persists: particular programs such as Mendeley Desktop will ‘launch’ but only show the loading icon on the cursor; after a few seconds the program disappears from the list of open processes.
The Windows event manager points to nvoglv32.dll as the culprit.
Log:
Faulting application name: MendeleyDesktop.exe, version: 1.19.8.0, time stamp: 0x5fdca73d
Faulting module name: nvoglv32.dll, version: 31.0.15.5244, time stamp: 0x6639f5f2
Fault offset: 0x00caf686
Faulting process id: 0x5dec
Faulting application start time: 0x01daaaeb974fcd23
Faulting application path: C:\Program Files (x86)\Mendeley Desktop\MendeleyDesktop.exe
Faulting module path: C:\windows\System32\DriverStore\FileRepository\nvlti.inf_amd64_00cc3a692c57c34d\nvoglv32.dll
Report Id: e5b1544e-7b4e-492b-bef0-dfc628c5af92
Do you have any suggestions for how to fix or avoid this?
We have an internal bug tracking this issue now. It is hard to confirm we are fixing the same issue without the repro steps. Could you share the crash dump from MendeleyDesktop.exe?
I would love to, but I might need some help with that. Mendeley Desktop unfortunately doesn’t seem to generate crash dumps (at least not during this particular crash). Would you know where I can find those? I tried producing a verbose crash log as per (https://service.elsevier.com/app/answers/detail/a_id/19595/p/10524/supporthub/mendeley/) but it seems that the program crashes even before this log is produced.
Is there a program that you know of that relies on nvoglv32.dll and has detailed crash dumps? I can install it and give it a try.
I am not familiar with Mendeley Desktop. I was referring to Windows user mode crash dumps from Microsoft documentation. It does not depend on the application or specific DLL.
Thank you Wen_Su, I was unfamiliar with that feature. I have created a dump file. Unfortunately it is in the wrong file format to upload here: I have uploaded it to WeTransfer. You can access the link here: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free . Please let me know if I can provide any other material.
Thank you for the crash dump. WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
I have reviewed the dump. The crash signature matches our driver team setup with another internal application. This confirms the bug is similar. We will deliver the bug fix with in our next driver release.
Great, glad the issue was already on your radar from another bug. Out of curiosity: driver version 555.85 was just released today. Is the bug fix included in that release? I did a clean install and tested the software again: the crash still occured. Please let me know if you’d like me to upload another crash dump.
555.85 does not have the fix.
Hi Socrates,
The OpenGL driver optimizes the modules loaded by the current process. Some application DLLs provide invalid data that can lead to crashes. We hardened the NVIDIA OpenGL driver to detect this and ignore ill-behaving DLLs.
Our internal fix is under verification. It should be available soon in the upcoming driver release. Thanks for your report.
We also hope to root cause which application/dlls cause the unexpected behavior when interacting with OpenGL driver. Are you running any Anti-Malware or Falcon software (e.g. CrowdStrike Falcon) with MendeleyDesktop?
Understood, will install the next driver release.
Thank you for the update qgu, sorry I didn’t see your post. Yes, I’m running this program on an enterprise device that’s being managed with/protected by Crowdstrike Falcon, Citrix Workspace, BigFix, and probably some additional services that I’m unaware of.
Now able to run the particular application after installing driver 555.99 today
Same here. Thanks everyone.
I am trying to run the 32-bit version of TheSky under Windows 10 (64-bit). The computer is running CrowdStrike.
This is the error log I get.
Is there a fix for this?
Description
Faulting Application Path: C:\Program Files (x86)\Software Bisque\TheSkyX Professional Edition\TheSkyX.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: TheSkyX.exe
Application Version: 10.3.0.8461
Application Timestamp: 547f3ef0
Fault Module Name: nvoglv32.DLL
Fault Module Version: 10.18.13.5330
Fault Module Timestamp: 558103f1
Exception Code: c0000005
Exception Offset: 00b7f9bd
OS Version: 10.0.18362.2.0.0.256.4
Locale ID: 1033
Additional Information 1: 1cff
Additional Information 2: 1cff56558d27203058492e76ec8fe11d
Additional Information 3: 1b44
Additional Information 4: 1b448ed1e635db8da03e4e884d5ffc10
Extra information about the problem
Bucket ID: 96801aa1d30403f71c64d3a6ae506fdd (2045992843575586781)
I have the same issue with the last driver 556.12 released on 06/27/2024. Error code 019917D6760898EFEC81620859100AB7 nvoglv32.dll please fix it soon.
Hi Richard,
If you still have the repro, please post more details (application, GPU, OS, running with Crowdstrike?) with a crash dump so we can inspect if it’s the same issue.
