Nvrtspoutsinkbin rtsp path
I am using “nvrtspoutsinkbin” as the sink in a C app. It seems to output the RTSP stream on rtsp://localhost:8554/ds-test. Using gst-inspect-1.0 I was able to modify the port. But I could not find a property for the path “ds-test”. How can I modify that?
• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version: 6.3
**• JetPack Version (valid for Jetson only): 5.1.1-b56 **
• TensorRT Version: 8.5.2.2
• Issue Type( questions, new requirements, bugs): question
It cannot be changed at the moment.
That is good advice, we will look at it and get back to you as soon as there is progress.
