Unable to find Gst-nvmultiurisrcbin in DS6.2
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• Issue Type( questions, new requirements, bugs) Question
Output of gst-inspect-1.0 nvmultiurisrcbin inside DS6.2 container (nvcr.io/nvidia/deepstream-l4t:6.2-triton) results in No such element or plugin 'nvmultiurisrcbin'
I have tried executing the scripts below
/opt/nvidia/deepstream/deepstream-6.2/install.sh
/opt/nvidia/deepstream/deepstream-6.2/user_additional_install.sh
As per the docs, this plugin should be available for DS 6.2. Please let me know if I am missing something.
Can you upgrade your JetPack version to 5.1.2GA and use nvcr.io/nvidia/deepstream-l4t:6.3-samples container?
The upgrade might not be possible at the moment. Please help set it up with DS6.2 and Jetpack 5.1.1 itself. Does the plugin work as expected for you? I’d like to identify the root cause and resolve this issue.
The solution is to upgrade. to JetPack 5.1.2GA and use nvcr.io/nvidia/deepstream-l4t:6.3-samples container.
