• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version7.0 in docker
Try to run the below command line.
/opt/nvidia/deepstream/deepstream/install.sh
Then check if there is output from the following command
gst-inspect-1.0 nvmultiurisrcbin
root@ps:/opt/nvidia/deepstream/deepstream# gst-inspect-1.0 nvmultiurisrcbin
Factory Details:
Rank primary (256)
Long-name NvMultiUri Bin
Klass NvMultiUri Bin
Description Nvidia DeepStreamSDK NvMultiUri Bin
Author NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries @ https://devtalk.nvidia.com/default/board/209/
Plugin Details:
Name nvdsgst_nvmultiurisrcbin
Description Deepstream SDK nvmultiurisrcbin Bin
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvmultiurisrcbin.so
Version 7.0.0
License Proprietary
Source module DeepStream SDK nvmultiurisrcbin Bin
Binary package Deepstream SDK nvmultiurisrcbin Bin
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBin
+----GstDsNvMultiUriBin
Implemented Interfaces:
GstChildProxy
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { (string)NV12, (string)RGBA, (string)I420 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
audio/x-raw(memory:NVMM)
format: { (string)S16LE, (string)F32LE }
layout: interleaved
channels: [ 1, 2147483647 ]
rate: [ 1, 2147483647 ]
Element has no clocking capabilities
is this ok?
Yes, I think the following code can work normally.
source = Gst.ElementFactory.make("nvmultiurisrcbin", "nvmultiurisrcbin")
thank you ! this is ok now, should update python API docs and add a python example in deepstream_python_apps
project
