• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.1 Docker
There isn’t much information online, and I read the documentation many times, still dont know how to write it.
need to multi rtsp in and multi rtsp out streams
You may refer to /opt/nvidia/deepstream/deepstream/service-maker/sources/apps/python/pipeline_api/deepstream_test5_app
command
python3 deepstream_test5.py -c test5_b16_dynamic_source.yaml -s source_list_dynamic.yaml
log
UniqueSensorId2[UniqueSensorName2] 9.33 (9.33) UniqueSensorId1[UniqueSensorName1] 10.22 (9.33)
(python3:51123): GStreamer-WARNING **: 06:55:59.073: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder1:sink> Got data flow before segment event
(python3:51123): GStreamer-WARNING **: 06:55:59.162: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder1:sink> Got data flow before segment event
(python3:51123): GStreamer-WARNING **: 06:55:59.857: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder0:sink> Got data flow before segment event
Active sources : 2
Fri Nov 15 06:56:00 2024
**PERF:
UniqueSensorId2[UniqueSensorName2] 9.59 (9.34) UniqueSensorId1[UniqueSensorName1] 9.60 (9.34)
(python3:51123): GStreamer-WARNING **: 06:56:00.294: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder0:sink> Got data flow before segment event
(python3:51123): GStreamer-WARNING **: 06:56:00.900: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder1:sink> Got data flow before segment event
Active sources : 2
Fri Nov 15 06:56:01 2024
**PERF:
UniqueSensorId2[UniqueSensorName2] 9.38 (9.33) UniqueSensorId1[UniqueSensorName1] 9.56 (9.35)
(python3:51123): GStreamer-WARNING **: 06:56:01.247: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<nvv4l2decoder0:sink> Got data flow before segment event
Active sources : 2
Fri Nov 15 06:56:02 2024
**PERF:
UniqueSensorId2[UniqueSensorName2] 9.63 (9.35) UniqueSensorId1[UniqueSensorName1] 9.63 (9.36)
Active sources : 2
Fri Nov 15 06:56:03 2024
**PERF:
UniqueSensorId2[UniqueSensorName2] 9.99 (9.36) UniqueSensorId1[UniqueSensorName1] 9.99 (9.38)
# gpu pwr gtemp mtemp sm mem enc dec jpg ofa mclk pclk rxpci txpci
# Idx W C C % % % % % % MHz MHz MB/s MB/s
0 118 47 - 2 1 0 3 0 0 9501 1695 1 0
PERF value is too low,do you know why?
I’ve tried the original “python3 deepstream_test5.py -c test5_b16_dynamic_source.yaml -s source_list_dynamic.yaml” in my device. The FPS is around 29.9. Have you changed anything or done something with the sample?
no, I didn’t change anything
how to export deepstream_test5_app pipeline picture use Graphviz?
You can set the environment variable to dump the pipeline graph with service maker apps.
export GST_DEBUG_DUMP_DOT_DIR=/the folder for the dot file
system
Closed
December 4, 2024, 1:15am
8
