Jetson
• DeepStream Version
DeepStream7.0
JetPack6.0
• TensorRT Version
TensorRT: 8.6.2.3
CUDA: 12.2.140
bugs
gst-launch-1.0 nvurisrcbin
ERROR: pipeline could not be constructed: no element “nvurisrcbin”.
gst-inspect-1.0 nvurisrcbin
No such element or plugin ‘nvurisrcbin’
An error occurred when upgrading from deepstream6.0 to deepstream7.0
Tried rebuild but the problem was not solved
/opt/nvidia/deepstream/deepstream/install.sh
yuweiw
July 19, 2024, 7:11am
3
Could you run the command below and attach the log info?
ldd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so
robustel@nano:~$ ldd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so
linux-vdso.so.1 (0x0000ffffb20a8000)
libglib-2.0.so.0 => /lib/aarch64-linux-gnu/libglib-2.0.so.0 (0x0000ffffb1e00000)
libgobject-2.0.so.0 => /lib/aarch64-linux-gnu/libgobject-2.0.so.0 (0x0000ffffb1d80000)
libgstreamer-1.0.so.0 => /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0 (0x0000ffffb1c10000)
libgstvideo-1.0.so.0 => /lib/aarch64-linux-gnu/libgstvideo-1.0.so.0 (0x0000ffffb1b40000)
libgstrtspserver-1.0.so.0 => not found
libnvdsgst_dewarper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_dewarper.so (0x0000ffffb1a60000)
libnvdsgst_dsanalytics.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_dsanalytics.so (0x0000ffffb1a10000)
libnvdsgst_osd.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_osd.so (0x0000ffffb1940000)
libnvdsgst_infer.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_infer.so (0x0000ffffb1840000)
libnvdsgst_msgbroker.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_msgbroker.so (0x0000ffffb1820000)
libnvdsgst_msgconv.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_msgconv.so (0x0000ffffb1800000)
libnvdsgst_multistreamtiler.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_multistreamtiler.so (0x0000ffffb1730000)
libnvdsgst_tracker.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libnvdsgst_tracker.so (0x0000ffffb1640000)
libgstnvvideoconvert.so => /opt/nvidia/deepstream/deepstream-7.0/lib/gst-plugins/libgstnvvideoconvert.so (0x0000ffffb1560000)
libnvdsgst_smartrecord.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_smartrecord.so (0x0000ffffb1540000)
libnvdsgst_helper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_helper.so (0x0000ffffb1520000)
libnvdsgst_meta.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_meta.so (0x0000ffffb1500000)
libstdc++.so.6 => /lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000ffffb12d0000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffffb1120000)
/lib/ld-linux-aarch64.so.1 (0x0000ffffb206f000)
libpcre.so.3 => /lib/aarch64-linux-gnu/libpcre.so.3 (0x0000ffffb10a0000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000ffffb1000000)
libffi.so.8 => /lib/aarch64-linux-gnu/libffi.so.8 (0x0000ffffb0fe0000)
libgmodule-2.0.so.0 => /lib/aarch64-linux-gnu/libgmodule-2.0.so.0 (0x0000ffffb0fc0000)
libunwind.so.8 => /lib/aarch64-linux-gnu/libunwind.so.8 (0x0000ffffb0f80000)
libdw.so.1 => /lib/aarch64-linux-gnu/libdw.so.1 (0x0000ffffb0ec0000)
libgstbase-1.0.so.0 => /lib/aarch64-linux-gnu/libgstbase-1.0.so.0 (0x0000ffffb0e30000)
liborc-0.4.so.0 => /lib/aarch64-linux-gnu/liborc-0.4.so.0 (0x0000ffffb0d90000)
libnvds_dewarper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_dewarper.so (0x0000ffffb0bf0000)
libnvdsbufferpool.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so.1.0.0 (0x0000ffffb0bd0000)
libnvds_csvparser.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_csvparser.so (0x0000ffffb0ba0000)
libnvds_nvtxhelper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_nvtxhelper.so (0x0000ffffb0b80000)
libnvbufsurface.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0 (0x0000ffffb0ab0000)
libnvbufsurftransform.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so.1.0.0 (0x0000ffffaf600000)
libcuda.so.1 => /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1 (0x0000ffffad940000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000ffffad910000)
libnvds_dsanalytics.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_dsanalytics.so (0x0000ffffad8f0000)
libnvds_meta.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_meta.so (0x0000ffffad8d0000)
libyaml-cpp.so.0.7 => /lib/aarch64-linux-gnu/libyaml-cpp.so.0.7 (0x0000ffffad880000)
libnvds_osd.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_osd.so (0x0000ffffad550000)
libnvdsgst_customhelper.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_customhelper.so (0x0000ffffad530000)
libnvds_infer.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_infer.so (0x0000ffffad410000)
libnvds_msgbroker.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_msgbroker.so (0x0000ffffad3f0000)
libnvds_msgconv.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_msgconv.so (0x0000ffffad160000)
libnvdsgst_3d_gst.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvdsgst_3d_gst.so (0x0000ffffad140000)
libgstpbutils-1.0.so.0 => /lib/aarch64-linux-gnu/libgstpbutils-1.0.so.0 (0x0000ffffad0e0000)
libgstrtp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstrtp-1.0.so.0 (0x0000ffffad0a0000)
liblzma.so.5 => /lib/aarch64-linux-gnu/liblzma.so.5 (0x0000ffffad060000)
libelf.so.1 => /lib/aarch64-linux-gnu/libelf.so.1 (0x0000ffffad030000)
libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000ffffad000000)
libbz2.so.1.0 => /lib/aarch64-linux-gnu/libbz2.so.1.0 (0x0000ffffacfd0000)
libnvrm_mem.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so (0x0000ffffacfb0000)
libnvrm_surface.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so (0x0000ffffacf70000)
libnvrm_chip.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so (0x0000ffffacf50000)
libEGL.so.1 => /lib/aarch64-linux-gnu/libEGL.so.1 (0x0000ffffacf20000)
libnvos.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so (0x0000ffffacef0000)
libnvbuf_fdmap.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0 (0x0000ffffaced0000)
libnvrm_host1x.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so (0x0000ffffacea0000)
libnvvic.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so (0x0000fffface70000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000fffface50000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000fffface30000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000fffface10000)
libnvrm_gpu.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so (0x0000ffffacd90000)
libcairo.so.2 => /lib/aarch64-linux-gnu/libcairo.so.2 (0x0000ffffacc60000)
libpango-1.0.so.0 => /lib/aarch64-linux-gnu/libpango-1.0.so.0 (0x0000ffffacbe0000)
libpangocairo-1.0.so.0 => /lib/aarch64-linux-gnu/libpangocairo-1.0.so.0 (0x0000ffffacbc0000)
libnvds_utils.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_utils.so (0x0000ffffac2e0000)
libnvparsers.so.8 => /lib/aarch64-linux-gnu/libnvparsers.so.8 (0x0000ffffabf70000)
libnvonnxparser.so.8 => /lib/aarch64-linux-gnu/libnvonnxparser.so.8 (0x0000ffffabcb0000)
libnvinfer.so.8 => /lib/aarch64-linux-gnu/libnvinfer.so.8 (0x0000ffff9db00000)
libnvinfer_plugin.so.8 => /lib/aarch64-linux-gnu/libnvinfer_plugin.so.8 (0x0000ffff9c5f0000)
libnvds_inferutils.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_inferutils.so (0x0000ffff9c5c0000)
libnvds_inferlogger.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_inferlogger.so (0x0000ffff9c5a0000)
libnvds_logger.so => /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_logger.so (0x0000ffff9c580000)
libjson-glib-1.0.so.0 => /lib/aarch64-linux-gnu/libjson-glib-1.0.so.0 (0x0000ffff9c540000)
libuuid.so.1 => /lib/aarch64-linux-gnu/libuuid.so.1 (0x0000ffff9c520000)
libgstapp-1.0.so.0 => /lib/aarch64-linux-gnu/libgstapp-1.0.so.0 (0x0000ffff9c4f0000)
libgstaudio-1.0.so.0 => /lib/aarch64-linux-gnu/libgstaudio-1.0.so.0 (0x0000ffff9c460000)
libgsttag-1.0.so.0 => /lib/aarch64-linux-gnu/libgsttag-1.0.so.0 (0x0000ffff9c410000)
libnvsciipc.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so (0x0000ffff9c3d0000)
libnvsocsys.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so (0x0000ffff9c3b0000)
libnvrm_sync.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so (0x0000ffff9c390000)
libGLdispatch.so.0 => /lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x0000ffff9c200000)
libnvrm_stream.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so (0x0000ffff9c1e0000)
libnvcolorutil.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so (0x0000ffff9c1b0000)
libnvtegrahv.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so (0x0000ffff9c190000)
libpixman-1.so.0 => /lib/aarch64-linux-gnu/libpixman-1.so.0 (0x0000ffff9c110000)
libfontconfig.so.1 => /lib/aarch64-linux-gnu/libfontconfig.so.1 (0x0000ffff9c0b0000)
libfreetype.so.6 => /lib/aarch64-linux-gnu/libfreetype.so.6 (0x0000ffff9bfe0000)
libpng16.so.16 => /lib/aarch64-linux-gnu/libpng16.so.16 (0x0000ffff9bf90000)
libxcb-shm.so.0 => /lib/aarch64-linux-gnu/libxcb-shm.so.0 (0x0000ffff9bf70000)
libxcb.so.1 => /lib/aarch64-linux-gnu/libxcb.so.1 (0x0000ffff9bf30000)
libxcb-render.so.0 => /lib/aarch64-linux-gnu/libxcb-render.so.0 (0x0000ffff9bf10000)
libXrender.so.1 => /lib/aarch64-linux-gnu/libXrender.so.1 (0x0000ffff9bef0000)
libX11.so.6 => /lib/aarch64-linux-gnu/libX11.so.6 (0x0000ffff9bda0000)
libXext.so.6 => /lib/aarch64-linux-gnu/libXext.so.6 (0x0000ffff9bd70000)
libgio-2.0.so.0 => /lib/aarch64-linux-gnu/libgio-2.0.so.0 (0x0000ffff9bb70000)
libfribidi.so.0 => /lib/aarch64-linux-gnu/libfribidi.so.0 (0x0000ffff9bb40000)
libthai.so.0 => /lib/aarch64-linux-gnu/libthai.so.0 (0x0000ffff9bb20000)
libharfbuzz.so.0 => /lib/aarch64-linux-gnu/libharfbuzz.so.0 (0x0000ffff9ba40000)
libpangoft2-1.0.so.0 => /lib/aarch64-linux-gnu/libpangoft2-1.0.so.0 (0x0000ffff9ba10000)
libnvdla_compiler.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_compiler.so (0x0000ffff9b220000)
libcudla.so.1 => /usr/local/cuda/lib64/libcudla.so.1 (0x0000ffff9b1f0000)
libcublas.so.12 => /usr/local/cuda/lib64/libcublas.so.12 (0x0000ffff93d20000)
libcublasLt.so.12 => /usr/local/cuda/lib64/libcublasLt.so.12 (0x0000ffff755b0000)
libcudnn.so.8 => /lib/aarch64-linux-gnu/libcudnn.so.8 (0x0000ffff75570000)
libcrypto.so.3 => /lib/aarch64-linux-gnu/libcrypto.so.3 (0x0000ffff75180000)
libexpat.so.1 => /lib/aarch64-linux-gnu/libexpat.so.1 (0x0000ffff75140000)
libbrotlidec.so.1 => /lib/aarch64-linux-gnu/libbrotlidec.so.1 (0x0000ffff75120000)
libXau.so.6 => /lib/aarch64-linux-gnu/libXau.so.6 (0x0000ffff75100000)
libXdmcp.so.6 => /lib/aarch64-linux-gnu/libXdmcp.so.6 (0x0000ffff750e0000)
libmount.so.1 => /lib/aarch64-linux-gnu/libmount.so.1 (0x0000ffff75080000)
libselinux.so.1 => /lib/aarch64-linux-gnu/libselinux.so.1 (0x0000ffff75040000)
libdatrie.so.1 => /lib/aarch64-linux-gnu/libdatrie.so.1 (0x0000ffff75020000)
libgraphite2.so.3 => /lib/aarch64-linux-gnu/libgraphite2.so.3 (0x0000ffff74ff0000)
libnvcudla.so => /lib/aarch64-linux-gnu/libnvcudla.so (0x0000ffff74fc0000)
libbrotlicommon.so.1 => /lib/aarch64-linux-gnu/libbrotlicommon.so.1 (0x0000ffff74f80000)
libbsd.so.0 => /lib/aarch64-linux-gnu/libbsd.so.0 (0x0000ffff74f50000)
libblkid.so.1 => /lib/aarch64-linux-gnu/libblkid.so.1 (0x0000ffff74f00000)
libpcre2-8.so.0 => /lib/aarch64-linux-gnu/libpcre2-8.so.0 (0x0000ffff74e60000)
libnvdla_runtime.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so (0x0000ffff74800000)
libmd.so.0 => /lib/aarch64-linux-gnu/libmd.so.0 (0x0000ffff747e0000)
Thank you for your attention, libgstrtspserver-1.0.so.0 is missing
yuweiw
July 19, 2024, 9:15am
5
It looks like there are no libgstrtspserver lib. You can try to install that by running the command below.
sudo apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \
libgstrtspserver-1.0-dev libx11-dev libyaml-cpp-dev
libgstrtspserver-1.0.so.0 has been installed, but the problem still exists
yuweiw
July 22, 2024, 1:55am
7
So when you run the ldd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so command, could the libgstrtspserver-1.0.so.0 be found now?
Yes
“No such element or plugin ‘nvurisrcbin’”
This problem has also been solved. It didn’t work yesterday, but suddenly it works today.
