Jetpack Version: 5.1
Deepstream version: 6.2
HW: AGX Xavier
Hi, I seem to be not be able to find the nvrtspoutsinkbin
element.
However I have a bench version of the same hardware where I can find this with gst-inspect-0
. but this freshly flashed unit does not have this (honestly I don’t rememebr how I got this working on my sandbox Jetson as it was a while ago)
in the module where that works we have
Factory Details:
Rank primary (256)
Long-name NvRtspOut Bin
Klass NvRtspOut Bin
Description Nvidia DeepStreamSDK RTSP Sink Bin. Internal Pipeline: queue->nvvideoconvert->encoder->codecparse->rtppay->udpsink.
Author NVIDIA Corporation. Deepstream for Tesla forum: https://devtalk.nvidia.com/default/board/209
Plugin Details:
Name nvdsgst_deepstream_bins
Description Deepstream SDK Common Gst Bins
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so
Version 6.2.0
License Proprietary
Source module DeepStream SDK Common Gst Bins
Binary package Deepstream SDK Common Gst Bins
Origin URL http://nvidia.com/
meaning the file is located at
this file exists in both jetsons so I think this may be a pathing issue but running justldconfig
does not do anything.
I suspected this plugin was blacklisted for some reason so on the unit I can’t find the plugin I cleared the gstreamer cache and did a gst-inspect and i got the following.
rm -rf ~/.cache/gstreamer-1.0
ganindu@syslogic-3:~/.cache/gstreamer-1.0$ gst-inspect-1.0 nvrtspoutsinkbin
sh: 0: getcwd() failed: No such file or directory
(gst-plugin-scanner:8426): GStreamer-WARNING **: 12:40:26.561: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8426): GStreamer-WARNING **: 12:40:26.580: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8426): GStreamer-WARNING **: 12:40:26.686: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so': libgstrtspserver-1.0.so.0: cannot open shared object file: No such file or directory
No such element or plugin 'nvrtspoutsinkbin'
