Nvsipl_query sample memory allocation error
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
When running the sipl_query we get this error:
libnvsipl_query.so: CNvmQuery.cpp : 75: GetDriverLibraries -memory allocation error for ldLibraryBuffer
libnvsipl_query.so: CNvMQuery.cpp : 126: ParseDatabase: Failed to find query json librariesError parsing NvSIPL database. Error code10
Thank you for reaching out. Based on my initial assessment, there doesn’t seem to be an issue on my end. To assist you better, could you please provide the complete command line you used and the corresponding full output? This information would greatly help me understand the context and work towards resolving the issue. Thank you in advance for your cooperation.
Went to the folder:
/usr/local/driveworks/tools/sensors/
Ran the command
./nvsipl_query
This occasionally shows up, sometimes it works, sometimes it fails and presents the error.
It seems that the issue you’re experiencing is not reproducible on my end. I’ve tried running the command “nvsipl_query” multiple times, and it worked without any errors. In order to assist you further, could you please provide the full output of “nvsipl_query” when the issue occurs?
Seems like the issue just went away, and it is now launching correctly. Will reach out if it shows up again.
As for a solution, we didn’t change anything, just rebooted the device and it now functions.
Are there some memory limitations or constraints applied to the system that we should be aware of? Can we set a higher buffer?
The error is likely related to the length of the value assigned to the ‘LD_LIBRARY_PATH’ variable, which appears to exceed the allowed limit.
