Hello.
I tested my model with deepstream.
1, test images (each image has different width and height) with jpeg format.
2. Here is command
gst-launch-1.0 multifilesrc location=/DB/%08d.jpeg caps=‘image/jpeg, framerate=10/1’ ! nvjpegdec ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 enable-padding=true ! nvinfer config-file-path=…/…/model/OBJ/pgie_config.txt ! nvdsosd ! nvvideoconvert ! jpegenc ! multifilesink location=out/%08d.jpeg
- I find a few overlapping image after enable-padding .
Accually a fire that is right side in the image is inferenced in this frame.
I want to make image as zero-padding on nvstreammux. Is there any good idea?
GPU
• DeepStream Version
5.0.1
• TensorRT Version
7.0.0.1
450.102.04
