On the nvv4l2h264enc gstreamer plugin, is there a way for the gstreamer plugin/pipeline to emit a signal when an I frame is generated by the encoder. I looked thru the properties exposed by this plugin and nothing seems to correlate to this.
Failing this, is there some way to setup the encoder so that the size of the frames would correlate (strongly) with an I frame
Victor
the nvv4l2h264enc itself does not emit any signal for NAL units, so you can evaluate the NAL units into the GStreamer application or creating a custom GStreamer Element that triggers a signal for each I frame.
You can control IDR interval using iframeinterval property into nvv4l2h264enc (See below validation).
Regards
Angel
gst-launch-1.0 videotestsrc num-buffers=100 ! nvvideoconvert ! nvv4l2h264enc iframeinterval=3 ! h264parse ! fakesink --gst-debug=*h264parse*:8
0:00:00.216927702 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 7 SPS, size 9
0:00:00.217294702 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 8 PPS, size 4
0:00:00.217605866 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 5 Slice IDR, size 8371
0:00:00.219581188 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7161
0:00:00.220241435 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7184
0:00:00.220906473 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 5 Slice IDR, size 9532
0:00:00.221505518 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7566
0:00:00.223057171 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7607
0:00:00.224524495 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 5 Slice IDR, size 9512
0:00:00.226403770 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7466
0:00:00.228368051 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 1 Slice, size 7536
0:00:00.230416763 1442 0x558fa95230 DEBUG h264parse gsth264parse.c:722:gst_h264_parse_process_nal:<h264parse0> processing nal of type 5 Slice IDR, size 9558
