**• Hardware Platform (Jetson / Xavier AGX)**Xavier AGX • DeepStream Version • JetPack Version (valid for Jetson only) 4.4 • TensorRT Version 7.1 • NVIDIA GPU Driver Version (valid for GPU only)
**• Issue Type( questions, new requirements, bugs)**new requirement • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)**NvVideoEncoder
Is there any plugin of NvVideoEncoder?
Does it has MV extract function?
if it hasn’t how to add this function?
if the plugin exist, how to get it?
if there is no such plugin, how to build the related plugin?
On Jetson platforms, we support gstreamer and jetson_multimedia_api. For video encoding, the implementation is nvv4l2h264enc, nvv4l2h265enc plugins in gstreamer, and NvVideoEcoder in jetson_multimedia_api. DeepStream SDK is based on gstreamer and you would need to use nvv4l2h264enc, nvv4l2h265enc.
the template of gstdsexample.cpp is very similar to gstyoloplugin.cpp, run their make file will produce a xxx.a(library), that is a plugin, is it?
Can it (e.g. libyolo-lib.a produceed by gstyoloplugin.cpp) be used standalone?
If application want to get BBox positions and size from libyolo-lib.a, need I create new external function within gstyoloplugin.cpp? or, how can I access it’s standard API?(e.g. source pad)
