Have anybody run successful a object detection on the Jeston TK1?
I try to run py-faster-rcnn but when i try to run it on the tk1 i get errors. On my PC it works fine.
I now the performance is not good on the tk1 but 1 FPS is enough for my work.
Thanks for help.
have a nice day and greetz from germany.
Torben
I’ve successfully ported darknet to tk1 which allows me to run YOLO3 on it. I can achieve 5fps using yolo3-tiny at 320x320 resolution which is sufficient for face detection.
My branch of darknet for tk1 is here: https://github.com/dtmoodie/darknet/tree/tk1
I got an exception
make: *** No rule to make target obj/gemm.o', needed by libdarknet.so’. Stop.
Thank you for your reply. I have successfully rebuild the project.
But when I have executed the command from tk1 branch:
./darknet detect cfg/yolov3.cfg /media/cluster_files/dev/weights/yolov3.weights data/dog.jpg
I have got only “asdf1” message. So the program has not found anything on the image
