I have a problem. I’m flashing binary using flash.sh script for the first time. below command
sudo ./flash.sh jetson-tx2 mmcblk0p1
And I could see “The target t186ref has been flashed successfully” log
But my tx2 board has kernel panic with follows logs.
What is problems. i flashed binary according to your quick start guide.
Plz tell me the reasons.
Were you adding swap space, or is there any customization? If not, could you try flashing again making the whole eMMC available? Try:
sudo ./flash.sh -S 29318MiB jetson-tx2 mmcblk0p1
Swapper is complaining, and several meta file systems are not there…I am thinking perhaps it didn’t have space, so flashing with a larger partition might be a good test.
Additional note: Be sure your host had enough disk space (“df -H”). Default flash uses about 25GB, using full partition size will use about 35GB on the host.
There was no any customization, i just used pure binary that decompress Tegra186_Linux_R27.1.0_aarch64.tbz2
i tried to flash followed by below command, but result is same, happen kernel panic
And i tried to test rootfs on sd card method belows
$ sudo mkfs.ext4 /dev/sdb1
$ mount /dev/sdb1 /media/doohan93
$ cd <your_L4T_root>/Linux_for_Tegra/rootfs
$ sudo cp -a * && sync
$sudo ./flash.sh jetson-tx2 mmcblk1p1
And i got kernel panic…what is a wrong with my procedure?
Thanks,
Doohan93
[ 5.822723] mmc1: tuning_window[5]: 0x0
[ 5.826957] mmc1: tuning_window[6]: 0x0
[ 5.831177] mmc1: tuning_window[7]: 0x0
[ 5.835381] sdhci: Tap value: 20 | Trim value: 5
[ 5.840379] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.851880] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.857821] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 6.194251] mmc2: new high speed SDHC card at address dafb
[ 6.200663] mmcblk1: mmc2:dafb SU16G 14.8 GiB
[ 6.212905] mmcblk1: p1
Rootdevice found: /dev/mmcblk1p1
[ 6.446011] EXT4-fs (mmcblk1p1): recovery complete
[ 6.451459] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 01:01:46 ] Rootfs mounted over mmcblk1p1
mount: mount point /mnt/proc does not exist
mount: mount point /mnt/sys does not exist
mount: mount point /mnt/dev does not exist
cp: cannot create regular file ‘etc/resolv.conf’: No such file or directory
[ 01:01:46 ] Switching from initrd to actual rootfs
chroot: failed to run command ‘/sbin/init’: No such file or directory
[ 6.500378] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 6.500378]
[ 6.511251] CPU3: stopping
[ 6.514484] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.15-tegra #1
[ 6.521464] Hardware name: quill (DT)
[ 6.525666] Call trace:
[ 6.528651] [] dump_backtrace+0x0/0x100
[ 6.534621] [] show_stack+0x14/0x1c
[ 6.540258] [] dump_stack+0x90/0xb4
[ 6.545901] [] handle_IPI+0x300/0x30c
[ 6.551723] [] gic_handle_irq+0x9c/0xb4
[ 6.557733] [] el1_irq+0x68/0xd8
[ 6.563150] [] cpuidle_enter+0x18/0x20
[ 6.569106] [] call_cpuidle+0x28/0x50
[ 6.574968] [] cpu_startup_entry+0x17c/0x340
[ 6.581434] [] secondary_start_kernel+0x130/0x168
[ 6.588333] [<000000008008192c>] 0x8008192c
[ 6.593134] CPU5: stopping
[ 6.596446] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.15-tegra #1
[ 6.603507] Hardware name: quill (DT)
“Host” is the desktop PC controlling the flash. Looks like you have enough disk space.
Question: Did you have an SD card in the Jetson during the flash?
When flashing for use with an SD card as root partition there are some details you may need to be aware of…
The eMMC is mmcblk0p1, the SD card is mmcblk1p1. When you flash to eMMC you can simply edit the extlinux.conf file and set to boot with SD card as root partition. The boot loader and configuration will remain on eMMC and the system can function without SD card (you might need a serial console if you are going to switch between optional boot entries, e.g., you might have a boot entry for eMMC and another for SD card…if one fails the other can rescue). Flashing to mmcblk0p1 will accomplish this with an edit to extlinux.conf. You can essentially boot to either SD or eMMC in this case (so long as the “/boot” of eMMC remains intact both SD and eMMC can boot…losing everything outside of “/boot” of eMMC would still allow SD card boot…losing the SD card would still allow eMMC boot).
If you flash to SD card, then configuration is going to all be on the SD card. eMMC will no longer be bootable without an SD card (you can put a new file system on the SD card, but if it fails there is no rescue via eMMC boot…flash would be required). In the case of SD card you can prepare an SD card separately, but I think you need to have the SD card formatted and in the Jetson as you enter recovery mode if you want flash to add a file system to the SD. Losing the SD card (such as removal from the socket or SD card losing its “/boot”) disables booting and rescue.
Are you interested in putting all boot configuration on the SD card, or do you want to keep eMMC functional and simply edit an alternate entry to boot to SD?
