• Hardware (NVIDIA A10G)
• Network Type (Ocdnet VIT and resnet 50 )
• Docker being used : nvcr.io/nvidia/tao/tao-toolkit:5.2.0-pyt2.1.0
• Training spec file :
load_pruned_graph: False
pruned_graph_path: ‘/results/prune/pruned_0.1.pth’
pretrained_model_path: ‘/data/ocdnet/ocdnet_fan_tiny_2x_icdar.pth’
backbone: fan_tiny_8_p4_hybrid
#backbone: deformable_resnet18
enlarge_feature_map_size: True
activation_checkpoint: True
train:
results_dir: /home/ubuntu/OCD/OCD-data-results
num_epochs: 80
#resume_training_checkpoint_path: ‘/home/ubuntu/OCD/ocdnet_craft_result/ocd_model_epoch_009.pth’
checkpoint_interval: 1
validation_interval: 1
is_dry_run: False
precision: fp16
model_ema: False
model_ema_decay: 0.999
trainer:
clip_grad_norm: 5.0
optimizer:
type: Adam
args:
lr: 0.001
lr_scheduler:
type: WarmupPolyLR
args:
warmup_epoch: 3
post_processing:
type: SegDetectorRepresenter
args:
thresh: 0.3
box_thresh: 0.55
max_candidates: 1000
unclip_ratio: 1.5
metric:
type: QuadMetric
args:
is_output_polygon: False
dataset:
train_dataset:
data_path: [‘/home/ubuntu/OCD/OCD-data/train-data’]
args:
pre_processes:
- type: IaaAugment
args:
- {‘type’:Fliplr, ‘args’:{‘p’:0.5}}
- {‘type’: Affine, ‘args’:{‘rotate’:[-45,45]}}
- {‘type’:Sometimes,‘args’:{‘p’:0.2, ‘then_list’:{‘type’: GaussianBlur, ‘args’:{‘sigma’:[1.5,2.5]}}}}
- {‘type’:Resize,‘args’:{‘size’:[0.5,3]}}
- type: EastRandomCropData
args:
max_tries: 50
keep_ratio: true
- type: MakeBorderMap
args:
shrink_ratio: 0.4
thresh_min: 0.3
thresh_max: 0.7
- type: MakeShrinkMap
args:
shrink_ratio: 0.4
min_text_size: 8
img_mode: BGR
filter_keys: [img_path,img_name,text_polys,texts,ignore_tags,shape]
ignore_tags: ['*', '###']
loader:
batch_size: 2
pin_memory: true
num_workers: 4
validate_dataset:
data_path: [‘/home/ubuntu/OCD/OCD-data/test-data’]
args:
pre_processes:
- type: Resize2D
args:
short_size:
- 1280
- 736
resize_text_polys: true
img_mode: BGR
filter_keys:
ignore_tags: [‘*’, ‘###’]
loader:
batch_size: 2
pin_memory: false
num_workers: 1
ISSUE : I have trained the model more than 10 times with same dataset and made some variations but model still fails to train and loss never drops less than 0.968 and less better with 0.9 and 1.0 . So, Please help me in this .
Text are in dot matrix format and here is a part of image.
Dataset Size is 5382 images including test and train
Training Terminal Snippet :
