Omnigraph set primpath issue
I am working on loading lidar from isaac sim using python. However, I don’t know how to put the lidarprim in the relationship into code in the current Isaac Read Lidar Beams Node. can you give me the answer?
Hi @leejisue
Just use the inputs:lidarPrim Add target(s) button for selecting the Lidar sensor as indicated in the documentation
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_ros_sensors.html?highlight=lidar%20beam#graph-explained
Isaac Read Lidar Beam Node: Retrieve information about the Lidar and data. For inputs:LidarPrim, add target to point to the Lidar sensor we just added at /World/turtlebot3_burger/base_scan/Lidar.
Also, if you want to set the target prim via Python code you can use the Isaac Sim core utility function set_targets
import omni.usd
from omni.isaac.core.utils.prims import set_targets
set_targets(prim=stage.GetPrimAtPath("/World/ActionGraph/isaac_read_lidar_beams_node"),
            attribute="inputs:lidarPrim",
            target_prim_paths=["/World/GenericSensor"])
I appreciate that your reply. But When i use the set_targets function the ImportError is comeout. Did the set_target function move elsewhere?
Hi @leejisue
The set_targets() function was added to prim utils in Isaac Sim 2022.2.0
For Isaac Sim 2022.1.1 use the following function:
from omni.isaac.core_nodes.scripts.utils import set_target_prims
set_target_prims(primPath="/World/ActionGraph/isaac_read_lidar_beams_node",
                 inputName="inputs:lidarPrim",
                 targetPrimPaths=["/World/GenericSensor"])
I set lidarprim on LidarBeamsNode in ActionGraph, but no change was made. Can you tell me what the problem is with this?
Hi @leejisue
According to the images, the Lidar Beams Node path is “/World/husky/lidar_graph/LidarBeamsNode”, but you are using “/World/lidar_graph/LidarBeamsNode” in the Python script
when i change the command… how can i fix it?
Can I get your email forwarded? I think I can send you my code.
Hi @leejisue
You can share the code on this topic, or, if you prefer, through a direct message (in this case, just click on my profile image in any post on this topic and select Message)
