I have the following code to create an encoding pipeline on Jetson AGX
but when I switched the encoder from omxh265enc to nvv4l2h265enc
I failed to create the pipeline (gst_element_link_many)
I googled on how to generate meaningful gstreamer debug messages, without success. But shouldn’t omxh265enc and nvv4l2h265enc be interchangeable?
Is this a bug?
gst_init(NULL, NULL); //Initialize Gstreamer
    //Create pipeline, and pipeline elements
    gstApp.pipeline = (GstPipeline*)gst_pipeline_new("mypipeline");
    gstApp.src    =   (GstAppSrc*)gst_element_factory_make("appsrc", "mysrc");
    gstApp.filter1 =  gst_element_factory_make ("capsfilter", "myfilter1");
    gstApp.encoder =  gst_element_factory_make ("omxh265enc", "myomx"); // nvv4l2h264enc omxh264enc nvh265enc vaapih265enc
#endif
    gstApp.filter2 =  gst_element_factory_make ("capsfilter", "myfilter2");
    gstApp.parser =   gst_element_factory_make("h265parse"  , "myparser");
    gstApp.mp4mux =    gst_element_factory_make("mp4mux"      , "mymux");
    gstApp.sink =     gst_element_factory_make ("filesink"  , NULL);
    if(	!gstApp.pipeline ||
            !gstApp.src      || !gstApp.filter1 ||
            !gstApp.encoder  || !gstApp.filter2 ||
            !gstApp.parser   || !gstApp.mp4mux  ||
            !gstApp.sink    )
            std::cout << "Error creating pipeline elements!" << std::endl;
            return false;
    //Attach elements to pipeline
    gst_bin_add_many(
            GST_BIN(gstApp.pipeline),
            (GstElement*)gstApp.src,
            gstApp.filter1,
            gstApp.encoder,
            gstApp.filter2,
            gstApp.parser,
            gstApp.mp4mux,
            gstApp.sink,
            NULL);
    //Set pipeline element attributes
    g_object_set (gstApp.src, "format", GST_FORMAT_TIME, NULL);
    g_object_set (gstApp.src, "is-live", TRUE, NULL);
    g_object_set(gstApp.src, "block", TRUE, NULL);
    g_object_set(gstApp.src, "is-live", TRUE, NULL);
    g_object_set(gstApp.src, "max-bytes",12000000,NULL);
    GstCaps *filtercaps1 = gst_caps_new_simple ("video/x-raw",
            "format", G_TYPE_STRING, "I420",
            "width", G_TYPE_INT, width,
            "height", G_TYPE_INT, height,
            "framerate", GST_TYPE_FRACTION, FPS, 1,
            NULL);
    g_object_set (G_OBJECT (gstApp.filter1), "caps", filtercaps1, NULL);
    g_object_set(G_OBJECT(gstApp.encoder), "bitrate", 12000000, NULL);
    g_object_set(G_OBJECT(gstApp.encoder), "control-rate", 0, NULL);
    g_object_set(G_OBJECT(gstApp.encoder), "preset-level", 3, NULL);
    GstCaps *filtercaps2 = gst_caps_new_simple ("video/x-h265",
            "stream-format", G_TYPE_STRING, "byte-stream",
            NULL);
    g_object_set (G_OBJECT (gstApp.filter2), "caps", filtercaps2, NULL);
    //Link elements together
    g_assert( gst_element_link_many(
            gstApp.filter1,
            gstApp.encoder,
            gstApp.filter2,
            gstApp.parser,
            gstApp.mp4mux,
            gstApp.sink,
            NULL ) );
