Supermicro SYS-4027TR
onboard matrox
8 K40m’s
CentOS 7.1
X was working prior to the install of CUDA or Nvidia drivers. I have installed and uninstalled each 2 times prior to deal with this.
I am wondering if anyone has successfully set up the BusID with CentOS/Fedora/RHEL for the onboard GPU.
Xorg.conf
xorg.conf.new
nvidia-xorg.conf
Are the locations that have the device headers for Xorg “card0” (I have also tried Card3 because somehow the xorg.config file was changed to card3 so I have done both. and all other permutations)
No matter what driver I use nouveau (including unblacklisting), mga, mgag200, vesa, vga xserver fails to load with error (EE)
It is proceeded by No Screen error (EE)
I will attach the bug report and other documents when I can get it back into run mode 3.
Jon
I have also tried the matrox driver from my kernel however it was not loaded and hence it did not work. I am trying to get the config files off the system. I cannot run any nvidia-settings commands other than help as I get the error “(nvidia settings:3532) Warning**: cound not open X display ERROR: the control display is undefined: please run nvidia-settings --help for usage information”
X.Org X Server 1.15.0
Release Date: 2013-12-27
[242948.361] X Protocol Version 11, Revision 0
[242948.386] Build Operating System: 2.6.32-220.17.1.el6.x86_64
[242948.412] Current Operating System: Linux tesla 3.10.0-229.20.1.el7.x86_64 #1 SMP Tue Nov 3 19:10:07 UTC 2015 x86_64
[242948.412] Kernel command line: BOOT_IMAGE=/vmlinuz-3.10.0-229.20.1.el7.x86_64 root=/dev/mapper/centos_tesla-root ro crashkernel=auto rd.lvm.lv=centos_tesla/swap rd.lvm.lv=centos_tesla/r$
[242948.507] Build Date: 10 April 2015 11:44:42AM
[242948.538] Build ID: xorg-x11-server 1.15.0-33.el7_1
[242948.570] Current version of pixman: 0.32.4
[242948.634] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[242948.634] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[242948.778] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 19 18:09:51 2015
[242948.816] (==) Using config file: "/etc/X11/xorg.conf"
[242948.851] (==) Using config directory: "/etc/X11/xorg.conf.d"
[242948.888] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[242948.889] (==) No Layout section. Using the first Screen section.
[242948.889] (==) No screen section available. Using defaults.
[242948.889] (**) |-->Screen "Default Screen Section" (0)
[242948.889] (**) | |-->Monitor "<default monitor>"
[242948.889] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[242948.889] (**) | |-->Device "Card3"
[242948.889] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[242948.889] (==) Automatically adding devices
[242948.889] (==) Automatically enabling devices
[242948.889] (==) Automatically adding GPU devices
[242948.889] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[242948.889] (**) ModulePath set to "/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[242948.889] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[242948.889] (II) Loader magic: 0x7f5e21b1a020
[242948.889] (II) Module ABI versions:
[242948.889] X.Org ANSI C Emulation: 0.4
[242948.889] X.Org Video Driver: 15.0
[242948.889] X.Org XInput driver : 20.0
[242948.889] X.Org Server Extension : 8.0
[242948.889] (II) xfree86: Adding drm device (/dev/dri/card1)
[242948.889] (II) xfree86: Adding drm device (/dev/dri/card2)
[242948.889] (II) xfree86: Adding drm device (/dev/dri/card3)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card4)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card0)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card5)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card6)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card7)
[242948.890] (II) xfree86: Adding drm device (/dev/dri/card8)
[242948.899] (--) PCI: (0:5:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xc9000000/16777216, 0x21800000000/17179869184, 0x21c00000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:6:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xc8000000/16777216, 0x21000000000/17179869184, 0x21400000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:9:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xc6000000/16777216, 0x20800000000/17179869184, 0x20c00000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:10:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xc5000000/16777216, 0x20000000000/17179869184, 0x20400000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI:*(0:15:3:0) 102b:0532:0000:0000 rev 10, Mem @ 0xc3000000/16777216, 0xcb000000/16384, 0xca800000/8388608, BIOS @ 0x????????/131072
[242948.899] (--) PCI: (0:132:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xfa000000/16777216, 0x23800000000/17179869184, 0x23c00000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:133:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xf9000000/16777216, 0x23000000000/17179869184, 0x23400000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:136:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xf7000000/16777216, 0x22800000000/17179869184, 0x22c00000000/33554432, BIOS @ 0x????????/65536
[242948.899] (--) PCI: (0:137:0:0) 10de:1023:10de:097e rev 161, Mem @ 0xf6000000/16777216, 0x22000000000/17179869184, 0x22400000000/33554432, BIOS @ 0x????????/65536
[242948.937] Initializing built-in extension Generic Event Extension
[242948.976] Initializing built-in extension SHAPE
[242949.019] Initializing built-in extension MIT-SHM
[242949.063] Initializing built-in extension XInputExtension
[242949.106] Initializing built-in extension XTEST
[242949.150] Initializing built-in extension BIG-REQUESTS
[242949.192] Initializing built-in extension SYNC
[242949.236] Initializing built-in extension XKEYBOARD
[242949.279] Initializing built-in extension XC-MISC
[242949.320] Initializing built-in extension XINERAMA
[242949.356] Initializing built-in extension XFIXES
[242949.392] Initializing built-in extension RENDER
[242949.428] Initializing built-in extension RANDR
[242949.464] Initializing built-in extension COMPOSITE
[242949.500] Initializing built-in extension DAMAGE
[242949.539] Initializing built-in extension MIT-SCREEN-SAVER
[242949.574] Initializing built-in extension DOUBLE-BUFFER
[242949.608] Initializing built-in extension RECORD
[242949.643] Initializing built-in extension DPMS
[242949.676] Initializing built-in extension Present
[242949.712] Initializing built-in extension X-Resource
[242949.746] Initializing built-in extension XVideo
[242949.782] Initializing built-in extension XVideo-MotionCompensation
[242949.816] Initializing built-in extension SELinux
[242949.848] Initializing built-in extension XFree86-VidModeExtension
[242949.881] Initializing built-in extension XFree86-DGA
[242949.913] Initializing built-in extension XFree86-DRI
[242949.944] Initializing built-in extension DRI2
[242949.944] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[242949.944] (II) "glx" will be loaded by default.
[242949.944] (II) LoadModule: "glx"
[242949.944] (II) Loading /usr/lib64/nvidia/xorg/libglx.so
[242949.957] (II) Module glx: vendor="NVIDIA Corporation"
[242949.957] compiled for 4.0.2, module version = 1.0.0
[242949.957] Module class: X.Org Server Extension
[242949.957] (II) NVIDIA GLX Module 352.55 Thu Oct 8 14:48:58 PDT 2015
[242949.990] Loading extension GLX
[242949.990] (II) LoadModule: "mgag200"
[242949.990] (WW) Warning, couldn't open module mgag200
[242949.990] (II) UnloadModule: "mgag200"
[242949.990] (II) Unloading mgag200
[242949.990] (EE) Failed to load module "mgag200" (module does not exist, 0)
[242949.990] (EE) No drivers available.
[242949.990] (EE)
Fatal server error:
[242950.055] (EE) no screens found(EE)
[242950.087] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[242950.223] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[242950.257] (EE)
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib64/xorg/modules"
FontPath "catalogue:/etc/X11/fontpath.d"
FontPath "built-ins"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
Identifier "Card3"
Driver "mgag200"
BusID "PCI:0f:03:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card3"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
nvidia-bug-report.log.gz (1.2 MB)
