CORRECTION: looks like I was wrong, clocks have finally went down after a long delay …
Related topics
| GPU stuck at reduced clocks | 3 | 5629 | October 7, 2011 | |
| My GPU Became Slower... after 1 month of not testing cuda | 18 | 12317 | August 23, 2010 | |
| clock rate on my GTX680 is only 706 MHz is it broken? | 6 | 9204 | April 29, 2012 | |
| Problem: core/memory/shader clocks are not reduced when GPU is idle | 5 | 3003 | December 26, 2009 | |
| Clock setting with 177.xx driver does it work for you? | 3 | 1885 | September 30, 2008 | |
| clockrate changes every time the program is run | 7 | 2448 | March 9, 2009 | |
| App for monitoring/changing GPU clock rate Very efficient - compared to Teapot :) | 23 | 106495 | July 1, 2010 | |
| deviceProperties - clockRate a constant value? | 3 | 4638 | April 9, 2008 | |
| what is the problem of my video card core clock is not correct | 0 | 2673 | January 16, 2009 | |
| gpu clock frequency changed | 2 | 7133 | September 25, 2008 |
