Only getting 1 bounding box at a time
jetson xavier AGX
deepstream works very well 90% of the time tracking multiple objects simultaneously but occasionally it will only produce 1 bounding box at a time. When there are multiple objects on the camera stream it will hold onto 1 object until it leave the screen and immediately snap to another object.
What setting do i need to change to stop this from happening?
Is it a tracker_config.yml issue? It is not a detection issue as all objects detect perfectly on their own
thanks
Can you share several videos for your issue? Which Deepstream version do you use?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
