I got two rtx 3090 cards for my deep learning setup. Both are connected to my X570 motherboard (which supports dual gpu SLI). I know both GPU cards are working because when I connect them individually they can be detected with nvidia-smi from their respective PCIE slots, it’s just nvidia-smi doesn’t recognize both of them together at the same time. Also in windows 10, 2x RTX 3090 cards are detected by the Geforce Experience software, it is ubuntu that is detecting only 1 out of the 2 cards.
In the terminal, with lspci |grep -i vga:
2d:00.0 VGA compatible controller: NVIDIA Corporation Device 2204 (rev a1)
2e:00.0 VGA compatible controller: NVIDIA Corporation Device 2204 (rev a1)
with dmesg | grep NVRM:
[ 2.582063] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 2.582065] NVRM: This can occur when a driver such as:
NVRM: nouveau, rivafb, nvidiafb or rivatv
NVRM: was loaded and obtained ownership of the NVIDIA device(s).
[ 2.582065] NVRM: Try unloading the conflicting kernel module (and/or
NVRM: reconfigure your kernel without the conflicting
NVRM: driver(s)), then try loading the NVIDIA kernel module
NVRM: again.
[ 2.582066] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.38 Thu Oct 22 06:06:59 UTC 2020
with nvidia-smi:
| NVIDIA-SMI 455.38 Driver Version: 455.38 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce RTX 3090 Off | 00000000:2D:00.0 On | N/A |
| 30% 43C P8 14W / 350W | 230MiB / 24245MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1078 G /usr/lib/xorg/Xorg 107MiB |
| 0 N/A N/A 1544 G /usr/bin/gnome-shell 116MiB |
| 0 N/A N/A 2342 G /usr/lib/firefox/firefox 4MiB |
I’ve reinstalled the driver via:
sudo apt install nvidia-driver-455
and also have cuda 11.1 installed.
Can anyone help me get both cards recognized by nvidia-smi? Thank you~!
