Getting OOM error after 10th Epoch
1st tried using one 1660 Ti with 6GB GPU Memory. Batch size for gpu is 1
2nd I tried using two 1660 Ti with 12 GB GPU Memory.Batch size per gpu is 1 still getting OOM
Here is the log:
[code]Epoch 00010: saving model to /workspace/tlt-experiments/experiment_dir_unpruned/weights/ssd_resnet18_epoch_010.tlt
WARNING:tensorflow:From ./ssd/box_coder/output_decoder_layer.py:83: to_float (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Instructions for updating:
Use tf.cast instead.
2019-11-20 06:09:36,167 [WARNING] tensorflow: From ./ssd/box_coder/output_decoder_layer.py:83: to_float (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Number of images in the evaluation dataset: 417
Producing predictions batch-wise: 0% 0/14 [00:00<?, ?it/s]2019-11-20 06:09:53.415515: W tensorflow/core/common_runtime/bfc_allocator.cc:267] Allocator (GPU_0_bfc) ran out of memory trying to allocate 3.96GiB. Current allocation summary follows.
2019-11-20 06:09:53.415716: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (256): Total Chunks: 425, Chunks in use: 425. 106.2KiB allocated for chunks. 106.2KiB in use in bin. 55.3KiB client-requested in use in bin.
2019-11-20 06:09:53.415773: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (512): Total Chunks: 188, Chunks in use: 188. 95.0KiB allocated for chunks. 95.0KiB in use in bin. 94.8KiB client-requested in use in bin.
2019-11-20 06:09:53.415807: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (1024): Total Chunks: 189, Chunks in use: 189. 189.2KiB allocated for chunks. 189.2KiB in use in bin. 189.0KiB client-requested in use in bin.
2019-11-20 06:09:53.415836: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (2048): Total Chunks: 176, Chunks in use: 176. 352.0KiB allocated for chunks. 352.0KiB in use in bin. 352.0KiB client-requested in use in bin.
2019-11-20 06:09:53.415864: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (4096): Total Chunks: 11, Chunks in use: 11. 47.5KiB allocated for chunks. 47.5KiB in use in bin. 47.5KiB client-requested in use in bin.
2019-11-20 06:09:53.415891: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (8192): Total Chunks: 0, Chunks in use: 0. 0B allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2019-11-20 06:09:53.415920: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (16384): Total Chunks: 16, Chunks in use: 16. 265.5KiB allocated for chunks. 265.5KiB in use in bin. 265.3KiB client-requested in use in bin.
2019-11-20 06:09:53.415949: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (32768): Total Chunks: 15, Chunks in use: 15. 508.5KiB allocated for chunks. 508.5KiB in use in bin. 508.5KiB client-requested in use in bin.
2019-11-20 06:09:53.415975: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (65536): Total Chunks: 22, Chunks in use: 22. 1.76MiB allocated for chunks. 1.76MiB in use in bin. 1.76MiB client-requested in use in bin.
2019-11-20 06:09:53.416003: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (131072): Total Chunks: 73, Chunks in use: 73. 11.16MiB allocated for chunks. 11.16MiB in use in bin. 11.13MiB client-requested in use in bin.
2019-11-20 06:09:53.416031: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (262144): Total Chunks: 47, Chunks in use: 47. 14.67MiB allocated for chunks. 14.67MiB in use in bin. 14.54MiB client-requested in use in bin.
2019-11-20 06:09:53.416059: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (524288): Total Chunks: 32, Chunks in use: 32. 17.40MiB allocated for chunks. 17.40MiB in use in bin. 17.05MiB client-requested in use in bin.
2019-11-20 06:09:53.416087: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (1048576): Total Chunks: 37, Chunks in use: 37. 40.12MiB allocated for chunks. 40.12MiB in use in bin. 40.12MiB client-requested in use in bin.
2019-11-20 06:09:53.416116: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (2097152): Total Chunks: 23, Chunks in use: 23. 55.90MiB allocated for chunks. 55.90MiB in use in bin. 55.90MiB client-requested in use in bin.
2019-11-20 06:09:53.416145: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (4194304): Total Chunks: 22, Chunks in use: 22. 102.44MiB allocated for chunks. 102.44MiB in use in bin. 98.61MiB client-requested in use in bin.
2019-11-20 06:09:53.416174: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (8388608): Total Chunks: 21, Chunks in use: 21. 190.00MiB allocated for chunks. 190.00MiB in use in bin. 189.00MiB client-requested in use in bin.
2019-11-20 06:09:53.416203: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (16777216): Total Chunks: 6, Chunks in use: 6. 109.23MiB allocated for chunks. 109.23MiB in use in bin. 104.86MiB client-requested in use in bin.
2019-11-20 06:09:53.416231: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (33554432): Total Chunks: 1, Chunks in use: 1. 32.00MiB allocated for chunks. 32.00MiB in use in bin. 18.00MiB client-requested in use in bin.
2019-11-20 06:09:53.416255: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (67108864): Total Chunks: 0, Chunks in use: 0. 0B allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2019-11-20 06:09:53.416279: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (134217728): Total Chunks: 0, Chunks in use: 0. 0B allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2019-11-20 06:09:53.416307: I tensorflow/core/common_runtime/bfc_allocator.cc:597] Bin (268435456): Total Chunks: 5, Chunks in use: 1. 4.22GiB allocated for chunks. 765.98MiB in use in bin. 765.98MiB client-requested in use in bin.
2019-11-20 06:09:53.416333: I tensorflow/core/common_runtime/bfc_allocator.cc:613] Bin for 3.96GiB was 256.00MiB, Chunk State:
2019-11-20 06:09:53.416369: I tensorflow/core/common_runtime/bfc_allocator.cc:619] Size: 264.58MiB | Requested Size: 2B | in_use: 0, prev: Size: 2.0KiB | Requested Size: 2.0KiB | in_use: 1
2019-11-20 06:09:53.416401: I tensorflow/core/common_runtime/bfc_allocator.cc:619] Size: 446.83MiB | Requested Size: 23.73MiB | in_use: 0, prev: Size: 256B | Requested Size: 24B | in_use: 1
2019-11-20 06:09:53.416432: I tensorflow/core/common_runtime/bfc_allocator.cc:619] Size: 759.38MiB | Requested Size: 759.38MiB | in_use: 0, next: Size: 2.0KiB | Requested Size: 2.0KiB | in_use: 1
2019-11-20 06:09:53.416462: I tensorflow/core/common_runtime/bfc_allocator.cc:619] Size: 2.04GiB | Requested Size: 32B | in_use: 0, prev: Size: 765.98MiB | Requested Size: 765.98MiB | in_use: 1
2019-11-20 06:09:53.416489: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f3138000000 of size 803188224
2019-11-20 06:09:53.416511: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f3167dfae00 of size 2185272832
2019-11-20 06:09:53.416533: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f31f0000000 of size 796262400
2019-11-20 06:09:53.416555: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f760000 of size 2048
2019-11-20 06:09:53.416576: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f760800 of size 2048
2019-11-20 06:09:53.416597: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761000 of size 1024
2019-11-20 06:09:53.416618: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761400 of size 1024
2019-11-20 06:09:53.416639: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761800 of size 512
2019-11-20 06:09:53.416660: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761a00 of size 512
2019-11-20 06:09:53.416681: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761c00 of size 256
2019-11-20 06:09:53.416702: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761d00 of size 256
2019-11-20 06:09:53.416723: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761e00 of size 256
2019-11-20 06:09:53.416743: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f761f00 of size 256
2019-11-20 06:09:53.416763: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762000 of size 256
2019-11-20 06:09:53.416784: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762100 of size 256
2019-11-20 06:09:53.416804: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762200 of size 256
2019-11-20 06:09:53.416825: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762300 of size 512
2019-11-20 06:09:53.416845: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762500 of size 512
2019-11-20 06:09:53.416867: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762700 of size 512
2019-11-20 06:09:53.416887: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762900 of size 512
2019-11-20 06:09:53.416908: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762b00 of size 1024
2019-11-20 06:09:53.416928: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f762f00 of size 1024
2019-11-20 06:09:53.416949: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f763300 of size 1024
2019-11-20 06:09:53.416970: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f763700 of size 1024
2019-11-20 06:09:53.416991: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f763b00 of size 2048
2019-11-20 06:09:53.417012: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f764300 of size 2048
2019-11-20 06:09:53.417032: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f764b00 of size 2048
2019-11-20 06:09:53.417053: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f765300 of size 2048
2019-11-20 06:09:53.417074: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f765b00 of size 2048
2019-11-20 06:09:53.417094: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f766300 of size 2048
2019-11-20 06:09:53.417115: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f766b00 of size 1024
2019-11-20 06:09:53.417135: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f766f00 of size 1024
2019-11-20 06:09:53.417155: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767300 of size 512
2019-11-20 06:09:53.417176: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767500 of size 512
2019-11-20 06:09:53.417196: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767700 of size 256
2019-11-20 06:09:53.417216: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767800 of size 256
2019-11-20 06:09:53.417236: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767900 of size 256
2019-11-20 06:09:53.417257: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767a00 of size 256
2019-11-20 06:09:53.417277: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767b00 of size 256
2019-11-20 06:09:53.417297: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767c00 of size 256
2019-11-20 06:09:53.417317: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767d00 of size 256
2019-11-20 06:09:53.417337: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f767e00 of size 512
2019-11-20 06:09:53.417358: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768000 of size 512
2019-11-20 06:09:53.417378: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768200 of size 512
2019-11-20 06:09:53.417398: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768400 of size 512
2019-11-20 06:09:53.417419: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768600 of size 1024
2019-11-20 06:09:53.417439: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768a00 of size 1024
2019-11-20 06:09:53.417460: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f768e00 of size 1024
2019-11-20 06:09:53.417480: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f769200 of size 1024
2019-11-20 06:09:53.417501: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f769600 of size 2048
2019-11-20 06:09:53.417521: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f769e00 of size 2048
2019-11-20 06:09:53.417542: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f76a600 of size 2048
2019-11-20 06:09:53.417562: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f321f76ae00 of size 2048
2019-11-20 06:09:53.417583: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f321f76b600 of size 277432832
2019-11-20 06:09:53.417605: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ac000000 of size 4155392
2019-11-20 06:09:53.417625: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ac3f6800 of size 256
2019-11-20 06:09:53.417646: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ac3f6900 of size 256
2019-11-20 06:09:53.417668: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ac3f6a00 of size 8310784
2019-11-20 06:09:53.417690: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32acbe3a00 of size 256
2019-11-20 06:09:53.417710: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32acbe3b00 of size 256
2019-11-20 06:09:53.417731: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32acbe3c00 of size 4155392
2019-11-20 06:09:53.417752: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32acfda400 of size 65536
2019-11-20 06:09:53.417774: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32acfea400 of size 589824
2019-11-20 06:09:53.417795: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad07a400 of size 32768
2019-11-20 06:09:53.417818: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad082400 of size 294912
2019-11-20 06:09:53.417841: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad0ca400 of size 147456
2019-11-20 06:09:53.417862: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad0ee400 of size 16384
2019-11-20 06:09:53.417884: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad0f2400 of size 221184
2019-11-20 06:09:53.417906: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad128400 of size 442368
2019-11-20 06:09:53.417927: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad194400 of size 110592
2019-11-20 06:09:53.417951: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad1af400 of size 165888
2019-11-20 06:09:53.417976: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad1d7c00 of size 331776
2019-11-20 06:09:53.418000: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad228c00 of size 82944
2019-11-20 06:09:53.418023: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad23d000 of size 1179648
2019-11-20 06:09:53.418047: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad35d000 of size 131072
2019-11-20 06:09:53.418070: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad37d000 of size 262144
2019-11-20 06:09:53.418093: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad3bd000 of size 4718592
2019-11-20 06:09:53.418116: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad83d000 of size 1048576
2019-11-20 06:09:53.418138: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32ad93d000 of size 4194304
2019-11-20 06:09:53.418161: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32add3d000 of size 18874368
2019-11-20 06:09:53.418184: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32aef3d000 of size 1048576
2019-11-20 06:09:53.418206: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af03d000 of size 9437184
2019-11-20 06:09:53.418229: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d000 of size 256
2019-11-20 06:09:53.418252: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d100 of size 256
2019-11-20 06:09:53.418274: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d200 of size 256
2019-11-20 06:09:53.418296: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d300 of size 256
2019-11-20 06:09:53.418318: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d400 of size 256
2019-11-20 06:09:53.418340: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d500 of size 256
2019-11-20 06:09:53.418363: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d600 of size 256
2019-11-20 06:09:53.418384: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d700 of size 256
2019-11-20 06:09:53.418406: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d800 of size 256
2019-11-20 06:09:53.418429: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93d900 of size 256
2019-11-20 06:09:53.418451: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93da00 of size 256
2019-11-20 06:09:53.418474: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93db00 of size 256
2019-11-20 06:09:53.418496: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93dc00 of size 256
2019-11-20 06:09:53.418519: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93dd00 of size 256
2019-11-20 06:09:53.418541: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93de00 of size 256
2019-11-20 06:09:53.418563: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93df00 of size 256
2019-11-20 06:09:53.418585: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e000 of size 256
2019-11-20 06:09:53.418607: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e100 of size 256
2019-11-20 06:09:53.418629: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e200 of size 256
2019-11-20 06:09:53.418651: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e300 of size 256
2019-11-20 06:09:53.418674: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e400 of size 256
2019-11-20 06:09:53.418696: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e500 of size 256
2019-11-20 06:09:53.418717: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e600 of size 256
2019-11-20 06:09:53.418739: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e700 of size 256
2019-11-20 06:09:53.418761: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e800 of size 256
2019-11-20 06:09:53.418783: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93e900 of size 256
2019-11-20 06:09:53.418806: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af93ea00 of size 7680
2019-11-20 06:09:53.418829: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af940800 of size 26112
2019-11-20 06:09:53.418852: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af946e00 of size 98048
2019-11-20 06:09:53.418875: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af95ed00 of size 391680
2019-11-20 06:09:53.418897: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32af9be700 of size 1566720
2019-11-20 06:09:53.418920: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32afb3cf00 of size 6220800
2019-11-20 06:09:53.418942: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012bb00 of size 256
2019-11-20 06:09:53.418965: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012bc00 of size 256
2019-11-20 06:09:53.418987: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012bd00 of size 256
2019-11-20 06:09:53.419009: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012be00 of size 256
2019-11-20 06:09:53.419031: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012bf00 of size 256
2019-11-20 06:09:53.419053: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32b012c000 of size 256
2019-11-20 06:09:53.419075: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Free at 0x7f32b012c100 of size 468532992
2019-11-20 06:09:53.419098: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2000000 of size 2359296
2019-11-20 06:09:53.419121: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2240000 of size 2359296
2019-11-20 06:09:53.419142: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2480000 of size 2359296
2019-11-20 06:09:53.419165: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f26c0000 of size 2359296
2019-11-20 06:09:53.419187: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2900000 of size 2359296
2019-11-20 06:09:53.419210: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2b40000 of size 2359296
2019-11-20 06:09:53.419232: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d80000 of size 1024
2019-11-20 06:09:53.419252: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d80400 of size 1024
2019-11-20 06:09:53.419273: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d80800 of size 1024
2019-11-20 06:09:53.419293: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d80c00 of size 1024
2019-11-20 06:09:53.419314: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d81000 of size 1024
2019-11-20 06:09:53.419335: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d81400 of size 1024
2019-11-20 06:09:53.419356: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d81800 of size 1024
2019-11-20 06:09:53.419376: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d81c00 of size 1024
2019-11-20 06:09:53.419396: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2d82000 of size 1179648
2019-11-20 06:09:53.419418: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2ea2000 of size 1179648
2019-11-20 06:09:53.419438: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f2fc2000 of size 1179648
2019-11-20 06:09:53.419459: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f30e2000 of size 1179648
2019-11-20 06:09:53.419479: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3202000 of size 1179648
2019-11-20 06:09:53.419499: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3322000 of size 1179648
2019-11-20 06:09:53.419519: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3442000 of size 1179648
2019-11-20 06:09:53.419540: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3562000 of size 1179648
2019-11-20 06:09:53.419560: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3682000 of size 1179648
2019-11-20 06:09:53.419580: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f37a2000 of size 1179648
2019-11-20 06:09:53.419601: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f38c2000 of size 1179648
2019-11-20 06:09:53.419621: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f39e2000 of size 1179648
2019-11-20 06:09:53.419660: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3b02000 of size 1179648
2019-11-20 06:09:53.419681: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c22000 of size 1024
2019-11-20 06:09:53.419702: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c22400 of size 1024
2019-11-20 06:09:53.419723: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c22800 of size 1024
2019-11-20 06:09:53.419743: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c22c00 of size 1024
2019-11-20 06:09:53.419764: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c23000 of size 1024
2019-11-20 06:09:53.419785: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c23400 of size 1024
2019-11-20 06:09:53.419805: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c23800 of size 1024
2019-11-20 06:09:53.419826: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c23c00 of size 1024
2019-11-20 06:09:53.419846: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c24000 of size 1024
2019-11-20 06:09:53.419867: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c24400 of size 1024
2019-11-20 06:09:53.419887: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c24800 of size 1024
2019-11-20 06:09:53.419909: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c24c00 of size 1024
2019-11-20 06:09:53.419929: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c25000 of size 1024
2019-11-20 06:09:53.419950: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c25400 of size 1024
2019-11-20 06:09:53.419970: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c25800 of size 1024
2019-11-20 06:09:53.419990: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c25c00 of size 1024
2019-11-20 06:09:53.420012: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c26000 of size 1024
2019-11-20 06:09:53.420032: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c26400 of size 1024
2019-11-20 06:09:53.420052: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c26800 of size 1024
2019-11-20 06:09:53.420072: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c26c00 of size 1024
2019-11-20 06:09:53.420093: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c27000 of size 1024
2019-11-20 06:09:53.420113: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c27400 of size 1024
2019-11-20 06:09:53.420134: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c27800 of size 1024
2019-11-20 06:09:53.420154: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c27c00 of size 1024
2019-11-20 06:09:53.420175: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c28000 of size 1024
2019-11-20 06:09:53.420196: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c28400 of size 1024
2019-11-20 06:09:53.420217: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c28800 of size 1024
2019-11-20 06:09:53.420237: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c28c00 of size 1024
2019-11-20 06:09:53.420257: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c29000 of size 1024
2019-11-20 06:09:53.420278: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c29400 of size 1024
2019-11-20 06:09:53.420299: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c29800 of size 1024
2019-11-20 06:09:53.420319: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c29c00 of size 1024
2019-11-20 06:09:53.420340: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2a000 of size 1024
2019-11-20 06:09:53.420361: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2a400 of size 1024
2019-11-20 06:09:53.420381: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2a800 of size 1024
2019-11-20 06:09:53.420401: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2ac00 of size 1024
2019-11-20 06:09:53.420422: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2b000 of size 1024
2019-11-20 06:09:53.420443: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2b400 of size 1024
2019-11-20 06:09:53.420463: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2b800 of size 1024
2019-11-20 06:09:53.420484: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2bc00 of size 1024
2019-11-20 06:09:53.420504: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2c000 of size 1024
2019-11-20 06:09:53.420524: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2c400 of size 1024
2019-11-20 06:09:53.420545: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2c800 of size 1024
2019-11-20 06:09:53.420565: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2cc00 of size 1024
2019-11-20 06:09:53.420585: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2d000 of size 1024
2019-11-20 06:09:53.420606: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2d400 of size 1024
2019-11-20 06:09:53.420626: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2d800 of size 1024
2019-11-20 06:09:53.420647: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2dc00 of size 1024
2019-11-20 06:09:53.420668: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2e000 of size 1024
2019-11-20 06:09:53.420689: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2e400 of size 1024
2019-11-20 06:09:53.420710: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2e800 of size 1024
2019-11-20 06:09:53.420730: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2ec00 of size 1024
2019-11-20 06:09:53.420751: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c2f000 of size 65536
2019-11-20 06:09:53.420772: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c3f000 of size 65536
2019-11-20 06:09:53.420792: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c4f000 of size 65536
2019-11-20 06:09:53.420813: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c5f000 of size 65536
2019-11-20 06:09:53.420833: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c6f000 of size 512
2019-11-20 06:09:53.420854: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c6f200 of size 512
2019-11-20 06:09:53.420875: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c6f400 of size 512
2019-11-20 06:09:53.420896: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c6f600 of size 512
2019-11-20 06:09:53.420916: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3c6f800 of size 589824
2019-11-20 06:09:53.420937: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3cff800 of size 589824
2019-11-20 06:09:53.420958: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3d8f800 of size 589824
2019-11-20 06:09:53.420978: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3e1f800 of size 589824
2019-11-20 06:09:53.420998: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3eaf800 of size 589824
2019-11-20 06:09:53.421019: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3f3f800 of size 589824
2019-11-20 06:09:53.421045: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f3fcf800 of size 589824
2019-11-20 06:09:53.421066: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f405f800 of size 589824
2019-11-20 06:09:53.421087: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f40ef800 of size 589824
2019-11-20 06:09:53.421107: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f417f800 of size 589824
2019-11-20 06:09:53.421127: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f420f800 of size 589824
2019-11-20 06:09:53.421147: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f429f800 of size 589824
2019-11-20 06:09:53.421168: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f432f800 of size 512
2019-11-20 06:09:53.421188: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f432fa00 of size 512
2019-11-20 06:09:53.421209: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f432fc00 of size 512
2019-11-20 06:09:53.421230: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f432fe00 of size 512
2019-11-20 06:09:53.421250: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330000 of size 512
2019-11-20 06:09:53.421270: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330200 of size 512
2019-11-20 06:09:53.421291: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330400 of size 512
2019-11-20 06:09:53.421311: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330600 of size 512
2019-11-20 06:09:53.421331: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330800 of size 512
2019-11-20 06:09:53.421352: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330a00 of size 512
2019-11-20 06:09:53.421372: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330c00 of size 512
2019-11-20 06:09:53.421393: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4330e00 of size 512
2019-11-20 06:09:53.421413: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331000 of size 512
2019-11-20 06:09:53.421434: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331200 of size 512
2019-11-20 06:09:53.421454: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331400 of size 512
2019-11-20 06:09:53.421475: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331600 of size 512
2019-11-20 06:09:53.421495: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331800 of size 512
2019-11-20 06:09:53.421516: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331a00 of size 512
2019-11-20 06:09:53.421536: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331c00 of size 512
2019-11-20 06:09:53.421556: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4331e00 of size 512
2019-11-20 06:09:53.421576: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332000 of size 512
2019-11-20 06:09:53.421596: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332200 of size 512
2019-11-20 06:09:53.421616: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332400 of size 512
2019-11-20 06:09:53.421637: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332600 of size 512
2019-11-20 06:09:53.421657: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332800 of size 512
2019-11-20 06:09:53.421677: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332a00 of size 512
2019-11-20 06:09:53.421697: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332c00 of size 512
2019-11-20 06:09:53.421718: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4332e00 of size 512
2019-11-20 06:09:53.421739: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333000 of size 512
2019-11-20 06:09:53.421760: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333200 of size 512
2019-11-20 06:09:53.421781: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333400 of size 512
2019-11-20 06:09:53.421801: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333600 of size 512
2019-11-20 06:09:53.421821: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333800 of size 512
2019-11-20 06:09:53.421841: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333a00 of size 512
2019-11-20 06:09:53.421862: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333c00 of size 512
2019-11-20 06:09:53.421882: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4333e00 of size 512
2019-11-20 06:09:53.421902: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334000 of size 512
2019-11-20 06:09:53.421923: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334200 of size 512
2019-11-20 06:09:53.421944: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334400 of size 512
2019-11-20 06:09:53.421964: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334600 of size 512
2019-11-20 06:09:53.421984: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334800 of size 512
2019-11-20 06:09:53.422005: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334a00 of size 512
2019-11-20 06:09:53.422026: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334c00 of size 512
2019-11-20 06:09:53.422047: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4334e00 of size 512
2019-11-20 06:09:53.422067: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335000 of size 512
2019-11-20 06:09:53.422087: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335200 of size 512
2019-11-20 06:09:53.422107: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335400 of size 512
2019-11-20 06:09:53.422127: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335600 of size 512
2019-11-20 06:09:53.422147: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335800 of size 512
2019-11-20 06:09:53.422168: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335a00 of size 512
2019-11-20 06:09:53.422188: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335c00 of size 512
2019-11-20 06:09:53.422208: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4335e00 of size 512
2019-11-20 06:09:53.422228: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4336000 of size 512
2019-11-20 06:09:53.422248: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4336200 of size 512
2019-11-20 06:09:53.422269: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4336400 of size 512
2019-11-20 06:09:53.422290: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4336600 of size 512
2019-11-20 06:09:53.422310: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4336800 of size 32768
2019-11-20 06:09:53.422331: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f433e800 of size 32768
2019-11-20 06:09:53.422352: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4346800 of size 32768
2019-11-20 06:09:53.422372: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f434e800 of size 32768
2019-11-20 06:09:53.422392: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4356800 of size 512
2019-11-20 06:09:53.422413: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4356a00 of size 512
2019-11-20 06:09:53.422435: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4356c00 of size 512
2019-11-20 06:09:53.422456: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4356e00 of size 512
2019-11-20 06:09:53.422476: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4357000 of size 512
2019-11-20 06:09:53.422497: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4357200 of size 512
2019-11-20 06:09:53.422517: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4357400 of size 512
2019-11-20 06:09:53.422539: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4357600 of size 512
2019-11-20 06:09:53.422560: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4357800 of size 294912
2019-11-20 06:09:53.422580: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f439f800 of size 294912
2019-11-20 06:09:53.422601: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f43e7800 of size 294912
2019-11-20 06:09:53.422621: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f442f800 of size 294912
2019-11-20 06:09:53.422642: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4477800 of size 512
2019-11-20 06:09:53.422662: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4477a00 of size 512
2019-11-20 06:09:53.422682: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4477c00 of size 512
2019-11-20 06:09:53.422703: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4477e00 of size 512
2019-11-20 06:09:53.422723: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478000 of size 512
2019-11-20 06:09:53.422743: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478200 of size 512
2019-11-20 06:09:53.422764: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478400 of size 512
2019-11-20 06:09:53.422784: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478600 of size 512
2019-11-20 06:09:53.422804: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478800 of size 512
2019-11-20 06:09:53.422824: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478a00 of size 512
2019-11-20 06:09:53.422845: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478c00 of size 512
2019-11-20 06:09:53.422865: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4478e00 of size 512
2019-11-20 06:09:53.422886: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479000 of size 512
2019-11-20 06:09:53.422906: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479200 of size 512
2019-11-20 06:09:53.422926: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479400 of size 512
2019-11-20 06:09:53.422946: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479600 of size 512
2019-11-20 06:09:53.422966: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479800 of size 512
2019-11-20 06:09:53.422986: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479a00 of size 512
2019-11-20 06:09:53.423007: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479c00 of size 512
2019-11-20 06:09:53.423027: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4479e00 of size 512
2019-11-20 06:09:53.423047: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447a000 of size 512
2019-11-20 06:09:53.423067: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447a200 of size 512
2019-11-20 06:09:53.423087: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447a400 of size 512
2019-11-20 06:09:53.423107: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447a600 of size 512
2019-11-20 06:09:53.423129: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447a800 of size 512
2019-11-20 06:09:53.423150: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447aa00 of size 512
2019-11-20 06:09:53.423170: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447ac00 of size 512
2019-11-20 06:09:53.423190: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447ae00 of size 512
2019-11-20 06:09:53.423210: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447b000 of size 512
2019-11-20 06:09:53.423230: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447b200 of size 512
2019-11-20 06:09:53.423250: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447b400 of size 512
2019-11-20 06:09:53.423270: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447b600 of size 512
2019-11-20 06:09:53.423290: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447b800 of size 512
2019-11-20 06:09:53.423311: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447ba00 of size 512
2019-11-20 06:09:53.423331: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447bc00 of size 512
2019-11-20 06:09:53.423351: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447be00 of size 512
2019-11-20 06:09:53.423371: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447c000 of size 512
2019-11-20 06:09:53.423392: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447c200 of size 512
2019-11-20 06:09:53.423413: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447c400 of size 512
2019-11-20 06:09:53.423433: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447c600 of size 512
2019-11-20 06:09:53.423453: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447c800 of size 512
2019-11-20 06:09:53.423474: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447ca00 of size 512
2019-11-20 06:09:53.423494: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447cc00 of size 512
2019-11-20 06:09:53.423514: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447ce00 of size 512
2019-11-20 06:09:53.423535: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447d000 of size 512
2019-11-20 06:09:53.423555: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447d200 of size 512
2019-11-20 06:09:53.423575: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447d400 of size 512
2019-11-20 06:09:53.423595: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447d600 of size 512
2019-11-20 06:09:53.423615: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447d800 of size 512
2019-11-20 06:09:53.423647: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447da00 of size 512
2019-11-20 06:09:53.423669: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447dc00 of size 512
2019-11-20 06:09:53.423690: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447de00 of size 512
2019-11-20 06:09:53.423711: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f447e000 of size 16384
2019-11-20 06:09:53.423732: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4482000 of size 16384
2019-11-20 06:09:53.423752: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4486000 of size 16384
2019-11-20 06:09:53.423773: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f448a000 of size 16384
2019-11-20 06:09:53.423794: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f448e000 of size 16384
2019-11-20 06:09:53.423814: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4492000 of size 16384
2019-11-20 06:09:53.423836: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4496000 of size 16384
2019-11-20 06:09:53.423857: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449a000 of size 16384
2019-11-20 06:09:53.423877: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449e000 of size 256
2019-11-20 06:09:53.423898: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449e100 of size 256
2019-11-20 06:09:53.423918: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449e200 of size 256
2019-11-20 06:09:53.423938: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449e300 of size 256
2019-11-20 06:09:53.423959: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f449e400 of size 147456
2019-11-20 06:09:53.423980: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f44c2400 of size 147456
2019-11-20 06:09:53.424001: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f44e6400 of size 147456
2019-11-20 06:09:53.424021: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f450a400 of size 147456
2019-11-20 06:09:53.424041: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f452e400 of size 147456
2019-11-20 06:09:53.424061: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4552400 of size 147456
2019-11-20 06:09:53.424082: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4576400 of size 147456
2019-11-20 06:09:53.424102: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f459a400 of size 147456
2019-11-20 06:09:53.424122: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f45be400 of size 147456
2019-11-20 06:09:53.424142: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f45e2400 of size 147456
2019-11-20 06:09:53.424163: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4606400 of size 147456
2019-11-20 06:09:53.424183: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f462a400 of size 147456
2019-11-20 06:09:53.424203: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f464e400 of size 147456
2019-11-20 06:09:53.424223: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4672400 of size 147456
2019-11-20 06:09:53.424243: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f4696400 of size 147456
2019-11-20 06:09:53.424263: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46ba400 of size 147456
2019-11-20 06:09:53.424284: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de400 of size 256
2019-11-20 06:09:53.424304: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de500 of size 256
2019-11-20 06:09:53.424325: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de600 of size 256
2019-11-20 06:09:53.424345: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de700 of size 256
2019-11-20 06:09:53.424366: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de800 of size 256
2019-11-20 06:09:53.424386: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46de900 of size 256
2019-11-20 06:09:53.424407: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dea00 of size 256
2019-11-20 06:09:53.424427: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46deb00 of size 256
2019-11-20 06:09:53.424447: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dec00 of size 256
2019-11-20 06:09:53.424467: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46ded00 of size 256
2019-11-20 06:09:53.424487: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dee00 of size 256
2019-11-20 06:09:53.424509: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46def00 of size 256
2019-11-20 06:09:53.424530: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df000 of size 256
2019-11-20 06:09:53.424550: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df100 of size 256
2019-11-20 06:09:53.424571: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df200 of size 256
2019-11-20 06:09:53.424591: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df300 of size 256
2019-11-20 06:09:53.424611: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df400 of size 256
2019-11-20 06:09:53.424631: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df500 of size 256
2019-11-20 06:09:53.424652: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df600 of size 256
2019-11-20 06:09:53.424672: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df700 of size 256
2019-11-20 06:09:53.424692: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df800 of size 256
2019-11-20 06:09:53.424712: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46df900 of size 256
2019-11-20 06:09:53.424732: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dfa00 of size 256
2019-11-20 06:09:53.424752: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dfb00 of size 256
2019-11-20 06:09:53.424772: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dfc00 of size 256
2019-11-20 06:09:53.424793: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dfd00 of size 256
2019-11-20 06:09:53.424813: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dfe00 of size 256
2019-11-20 06:09:53.424833: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46dff00 of size 256
2019-11-20 06:09:53.424854: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0000 of size 256
2019-11-20 06:09:53.424874: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0100 of size 256
2019-11-20 06:09:53.424894: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0200 of size 256
2019-11-20 06:09:53.424915: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0300 of size 256
2019-11-20 06:09:53.424935: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0400 of size 256
2019-11-20 06:09:53.424955: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0500 of size 256
2019-11-20 06:09:53.424976: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0600 of size 256
2019-11-20 06:09:53.424996: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0700 of size 256
2019-11-20 06:09:53.425016: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0800 of size 256
2019-11-20 06:09:53.425036: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0900 of size 256
2019-11-20 06:09:53.425056: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0a00 of size 256
2019-11-20 06:09:53.425077: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0b00 of size 256
2019-11-20 06:09:53.425098: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0c00 of size 256
2019-11-20 06:09:53.425119: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0d00 of size 256
2019-11-20 06:09:53.425141: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0e00 of size 256
2019-11-20 06:09:53.425161: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e0f00 of size 256
2019-11-20 06:09:53.425182: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1000 of size 256
2019-11-20 06:09:53.425203: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1100 of size 256
2019-11-20 06:09:53.425224: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1200 of size 256
2019-11-20 06:09:53.425244: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1300 of size 256
2019-11-20 06:09:53.425265: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1400 of size 256
2019-11-20 06:09:53.425285: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1500 of size 256
2019-11-20 06:09:53.425306: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1600 of size 256
2019-11-20 06:09:53.425326: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1700 of size 256
2019-11-20 06:09:53.425347: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1800 of size 256
2019-11-20 06:09:53.425368: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1900 of size 256
2019-11-20 06:09:53.425388: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1a00 of size 256
2019-11-20 06:09:53.425409: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1b00 of size 256
2019-11-20 06:09:53.425429: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1c00 of size 256
2019-11-20 06:09:53.425450: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1d00 of size 256
2019-11-20 06:09:53.425470: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1e00 of size 256
2019-11-20 06:09:53.425496: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e1f00 of size 256
2019-11-20 06:09:53.425516: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2000 of size 256
2019-11-20 06:09:53.425537: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2100 of size 256
2019-11-20 06:09:53.425557: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2200 of size 256
2019-11-20 06:09:53.425578: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2300 of size 256
2019-11-20 06:09:53.425598: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2400 of size 256
2019-11-20 06:09:53.425619: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2500 of size 256
2019-11-20 06:09:53.425639: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2600 of size 256
2019-11-20 06:09:53.425660: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2700 of size 256
2019-11-20 06:09:53.425680: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2800 of size 256
2019-11-20 06:09:53.425701: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2900 of size 256
2019-11-20 06:09:53.425721: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2a00 of size 256
2019-11-20 06:09:53.425743: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2b00 of size 256
2019-11-20 06:09:53.425765: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2c00 of size 256
2019-11-20 06:09:53.425785: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2d00 of size 256
2019-11-20 06:09:53.425806: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2e00 of size 256
2019-11-20 06:09:53.425826: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e2f00 of size 256
2019-11-20 06:09:53.425847: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3000 of size 256
2019-11-20 06:09:53.425867: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3100 of size 256
2019-11-20 06:09:53.425887: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3200 of size 256
2019-11-20 06:09:53.425908: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3300 of size 256
2019-11-20 06:09:53.425929: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3400 of size 256
2019-11-20 06:09:53.425951: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3500 of size 256
2019-11-20 06:09:53.425972: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3600 of size 256
2019-11-20 06:09:53.426003: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3700 of size 256
2019-11-20 06:09:53.426024: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3800 of size 256
2019-11-20 06:09:53.426045: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3900 of size 256
2019-11-20 06:09:53.426065: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3a00 of size 256
2019-11-20 06:09:53.426085: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3b00 of size 256
2019-11-20 06:09:53.426106: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3c00 of size 256
2019-11-20 06:09:53.426127: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3d00 of size 256
2019-11-20 06:09:53.426147: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3e00 of size 256
2019-11-20 06:09:53.426169: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e3f00 of size 256
2019-11-20 06:09:53.426199: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4000 of size 256
2019-11-20 06:09:53.426221: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4100 of size 256
2019-11-20 06:09:53.426241: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4200 of size 256
2019-11-20 06:09:53.426263: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4300 of size 256
2019-11-20 06:09:53.426284: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4400 of size 256
2019-11-20 06:09:53.426304: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4500 of size 256
2019-11-20 06:09:53.426325: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4600 of size 256
2019-11-20 06:09:53.426354: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4700 of size 256
2019-11-20 06:09:53.426376: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4800 of size 256
2019-11-20 06:09:53.426396: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4900 of size 256
2019-11-20 06:09:53.426417: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4a00 of size 256
2019-11-20 06:09:53.426437: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4b00 of size 256
2019-11-20 06:09:53.426458: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4c00 of size 256
2019-11-20 06:09:53.426478: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4d00 of size 256
2019-11-20 06:09:53.426499: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4e00 of size 256
2019-11-20 06:09:53.426520: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e4f00 of size 256
2019-11-20 06:09:53.426541: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e5000 of size 256
2019-11-20 06:09:53.426561: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e5100 of size 256
2019-11-20 06:09:53.426581: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e5200 of size 256
2019-11-20 06:09:53.426601: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e5300 of size 256
2019-11-20 06:09:53.426621: I tensorflow/core/common_runtime/bfc_allocator.cc:632] Chunk at 0x7f32f46e5400 of size 256
2019-11-20 06:09:53.426641: I tensorflow/core/common_runtim
