The Jetson GPIO ignores the “pull and down” instructions for GPIO.IN.
Consequently we cannot use a classic magnetic switch or limit switch.
Any suggestions on how to check if a door is open or closed?
I know it sounds like a silly question, but I can’t think of any efficient solution.
thanks
hello deusdixital,
am I understand correctly that you meant that Nano cannot recognize that high/low signal?
may I also know which pin you’re using, thanks
Hello Jerry,
There’s no way to control pull-up/-down on Jetson.
pull_up_down value is unused · Issue #5 · NVIDIA/jetson-gpio · GitHub
For example, connecting a switch between a GND pin and “pin 19 BOARD” I can’t see the state of the switch (open or closed).
import Jetson.GPIO as AGPIO
AGPIO.setmode(AGPIO.BOARD)
AGPIO.setup(19, AGPIO.IN, pull_up_down = AGPIO.PUD_UP)
def sensor():
if AGPIO.input(19): #TD
print("TD OPEN!")
else:
print("TD CLOSED!")
sensor()
AGPIO.cleanup()
If you run that code. Jetson responds that it will not use the “pull up down” parameters.
As far as I know jetson nano has no internal resistors on gpio so you should use external one for gpio pull up
