Is there any guide or document for enabling the pullup resistors in jetson nano?
with “GPIO Sysfs Interface for Userspace” I am able get most of the functionalities with respect to output, but with input (with no external pull up) it is not working, I have even tried with “Jetson.GPIO - Linux for Tegra” python library and it also did not worked even after making pullup high from that library (with no external pull up).
Finally I added external
resistors 1.5k, hooked to voltage source 3.3v then both the python library and sysfs are able to detect input (board pin no. 37)
so is there any way to enable internal pullup from userspace?
