Hello Jerry.
I cannot change the j41 configuration right now.
I use this commands:
cd Linux_for_Tegra/
./source_sync.sh
And had next log. There were no time to enter the tag tegra-l4t-r32.3.1.
user@Jetson:~/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra$ ./source_sync.sh
Downloading default kernel/kernel-4.9 source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/kernel-4.9'...
remote: Enumerating objects: 5193614, done.
remote: Counting objects: 100% (5193614/5193614), done.
remote: Compressing objects: 100% (799556/799556), done.
jvtneceiving objects: 0% (31165/5193614), 17.01 MiB | 445.00 KiB/s
vtnjReceiving objects: 0% (35585/5193614), 19.33 MiB | 627.00 KiB/s
remote: Total 5193614 (delta 4355668), reused 5191347 (delta 4353473)
Receiving objects: 100% (5193614/5193614), 932.44 MiB | 574.00 KiB/s, done.
Resolving deltas: 100% (4355668/4355668), done.
The default kernel/kernel-4.9 source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/kernel-4.9
Please enter a tag to sync /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/kernel-4.9 source to
(enter nothing to skip): Couldn't find tag yjdjvtn
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/kernel-4.9 source sync to tag yjdjvtn failed!
Downloading default kernel/nvgpu source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvgpu'...
remote: Enumerating objects: 54520, done.
remote: Counting objects: 100% (54520/54520), done.
remote: Compressing objects: 100% (12994/12994), done.
remote: Total 54520 (delta 34834), reused 52815 (delta 33324)
Receiving objects: 100% (54520/54520), 13.63 MiB | 547.00 KiB/s, done.
Resolving deltas: 100% (34834/34834), done.
The default kernel/nvgpu source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvgpu
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvgpu source sync to tag yjdjvtn failed!
Downloading default kernel/nvidia source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvidia'...
remote: Enumerating objects: 147992, done.
remote: Counting objects: 100% (147992/147992), done.
remote: Compressing objects: 100% (42461/42461), done.
remote: Total 147992 (delta 85136), reused 145343 (delta 82594)
Receiving objects: 100% (147992/147992), 37.73 MiB | 315.00 KiB/s, done.
Resolving deltas: 100% (85136/85136), done.
The default kernel/nvidia source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvidia
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/kernel/nvidia source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/soc/t18x source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x'...
remote: Enumerating objects: 1953, done.
remote: Counting objects: 100% (1953/1953), done.
remote: Compressing objects: 100% (833/833), done.
remote: Total 1953 (delta 816), reused 1702 (delta 691)
Receiving objects: 100% (1953/1953), 383.73 KiB | 142.00 KiB/s, done.
Resolving deltas: 100% (816/816), done.
The default hardware/nvidia/soc/t18x source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t18x source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/tegra/common source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common'...
remote: Enumerating objects: 270, done.
remote: Counting objects: 100% (270/270), done.
remote: Compressing objects: 100% (161/161), done.
remote: Total 270 (delta 109), reused 107 (delta 48)
Receiving objects: 100% (270/270), 103.06 KiB | 108.00 KiB/s, done.
Resolving deltas: 100% (109/109), done.
The default hardware/nvidia/platform/tegra/common source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/tegra/common source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t18x/common source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common'...
remote: Enumerating objects: 3623, done.
remote: Counting objects: 100% (3623/3623), done.
remote: Compressing objects: 100% (1080/1080), done.
remote: Total 3623 (delta 2102), reused 3250 (delta 1856)
Receiving objects: 100% (3623/3623), 637.33 KiB | 175.00 KiB/s, done.
Resolving deltas: 100% (2102/2102), done.
The default hardware/nvidia/platform/t18x/common source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t18x/quill source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill'...
remote: Enumerating objects: 1138, done.
remote: Counting objects: 100% (1138/1138), done.
remote: Compressing objects: 100% (499/499), done.
remote: Total 1138 (delta 603), reused 746 (delta 396)
Receiving objects: 100% (1138/1138), 200.39 KiB | 119.00 KiB/s, done.
Resolving deltas: 100% (603/603), done.
The default hardware/nvidia/platform/t18x/quill source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/quill source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/soc/t210 source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t210'...
remote: Enumerating objects: 3162, done.
remote: Counting objects: 100% (3162/3162), done.
remote: Compressing objects: 100% (1075/1075), done.
remote: Total 3162 (delta 1273), reused 2923 (delta 1165)
Receiving objects: 100% (3162/3162), 513.91 KiB | 161.00 KiB/s, done.
Resolving deltas: 100% (1273/1273), done.
The default hardware/nvidia/soc/t210 source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t210
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t210 source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t210/common source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common'...
remote: Enumerating objects: 1604, done.
remote: Counting objects: 100% (1604/1604), done.
remote: Compressing objects: 100% (485/485), done.
remote: Total 1604 (delta 690), reused 1408 (delta 583)
Receiving objects: 100% (1604/1604), 245.80 KiB | 123.00 KiB/s, done.
Resolving deltas: 100% (690/690), done.
The default hardware/nvidia/platform/t210/common source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/common source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t210/jetson source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson'...
remote: Enumerating objects: 2823, done.
remote: Counting objects: 100% (2823/2823), done.
remote: Compressing objects: 100% (855/855), done.
remote: Total 2823 (delta 1639), reused 2473 (delta 1408)
Receiving objects: 100% (2823/2823), 665.63 KiB | 150.00 KiB/s, done.
Resolving deltas: 100% (1639/1639), done.
The default hardware/nvidia/platform/t210/jetson source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/jetson source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t210/porg source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg'...
remote: Enumerating objects: 907, done.
remote: Counting objects: 100% (907/907), done.
remote: Compressing objects: 100% (257/257), done.
remote: Total 907 (delta 555), reused 799 (delta 488)
Receiving objects: 100% (907/907), 198.06 KiB | 112.00 KiB/s, done.
Resolving deltas: 100% (555/555), done.
The default hardware/nvidia/platform/t210/porg source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t210/porg source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/soc/t19x source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x'...
remote: Enumerating objects: 3492, done.
remote: Counting objects: 100% (3492/3492), done.
remote: Compressing objects: 100% (1409/1409), done.
remote: Total 3492 (delta 1445), reused 3250 (delta 1318)
Receiving objects: 100% (3492/3492), 645.70 KiB | 141.00 KiB/s, done.
Resolving deltas: 100% (1445/1445), done.
The default hardware/nvidia/soc/t19x source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t19x/common source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common'...
remote: Enumerating objects: 1242, done.
remote: Counting objects: 100% (1242/1242), done.
remote: Compressing objects: 100% (755/755), done.
remote: Total 1242 (delta 665), reused 945 (delta 483)
Receiving objects: 100% (1242/1242), 377.71 KiB | 144.00 KiB/s, done.
Resolving deltas: 100% (665/665), done.
The default hardware/nvidia/platform/t19x/common source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/common source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t19x/galen/bct source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/bct'...
remote: Enumerating objects: 389, done.
remote: Counting objects: 100% (389/389), done.
remote: Compressing objects: 100% (237/237), done.
remote: Total 389 (delta 271), reused 224 (delta 150)
Receiving objects: 100% (389/389), 259.74 KiB | 131.00 KiB/s, done.
Resolving deltas: 100% (271/271), done.
The default hardware/nvidia/platform/t19x/galen/bct source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/bct
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/bct source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/platform/t19x/galen/kernel-dts source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts'...
remote: Enumerating objects: 1187, done.
remote: Counting objects: 100% (1187/1187), done.
remote: Compressing objects: 100% (537/537), done.
remote: Total 1187 (delta 835), reused 927 (delta 649)
Receiving objects: 100% (1187/1187), 233.72 KiB | 115.00 KiB/s, done.
Resolving deltas: 100% (835/835), done.
The default hardware/nvidia/platform/t19x/galen/kernel-dts source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts source sync to tag yjdjvtn failed!
Downloading default hardware/nvidia/soc/tegra source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra'...
remote: Enumerating objects: 774, done.
remote: Counting objects: 100% (774/774), done.
remote: Compressing objects: 100% (457/457), done.
remote: Total 774 (delta 236), reused 625 (delta 155)
Receiving objects: 100% (774/774), 271.94 KiB | 115.00 KiB/s, done.
Resolving deltas: 100% (236/236), done.
The default hardware/nvidia/soc/tegra source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra source sync to tag yjdjvtn failed!
Downloading default u-boot source...
Cloning into '/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/u-boot'...
remote: Enumerating objects: 559980, done.
remote: Counting objects: 100% (559980/559980), done.
remote: Compressing objects: 100% (91089/91089), done.
remote: Total 559980 (delta 463141), reused 557457 (delta 460778)
Receiving objects: 100% (559980/559980), 112.33 MiB | 509.00 KiB/s, done.
Resolving deltas: 100% (463141/463141), done.
The default u-boot source is downloaded in: /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/u-boot
Please enter a tag to sync /home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/u-boot source to
/home/user/Загрузки/Tegra210_Linux_R32.3.1_aarch64/Linux_for_Tegra/sources/u-boot source sync to tag yjdjvtn failed!
