Gpio pull_up_down mode
I use GPIO to read Digital data from Motion sensor. (Motion sensor detect return 1, vice versa return 0)
I want my input pin in pull_up_down mode by function GPIO.setup() but I received a warning "Ignore pull_up_down "
If found this source in Gpio lib and It not accept to use pull_up_down.
My question is:
How can I use pull_up_down mode to set my input in pull_up ?
hello 111convit,
please refer to Jetson-GPIO sample, such as button_interrupt.py.
you may use the API to detect GPIO state changes. thanks
Hello JerryChang,
I checked this example, It is blocking and GPIO INPUT is in default (value = 1) .
My Gpio.INPut always have value = 1 (3.3 vol). How can I change It to 0 ?
I used function GPIO.setup() with parameter pull_up_down and It return ignore.
thanks
hello 111convit,
please check voltage levels match.
the Jetson would normally use a 3.3V “TTL” logic level. it probably fail when using 5V or 1.8V.
thanks
Motion sensor response voltage = 3.3v (if detected) , vice versa voltage = 0v
I used jetson.GPIO to read it. But It’s not working.
My problem: when Motion sensor return 1, Jetson read 1 and keep this value (Don’t change when Motion sensor return 0 )
I tested this sensor in Rasp3 and It worked normally.
hello 111convit,
could you please also share the hardware pin connections for reference,
thanks
My hardware config :
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(15, GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
I also tested in pin 37 and 23
Do U have any soutions for me?
I really need it.
hello 111convit,
please check this document, Jetson Nano Developer Kit 40-Pin Expansion Header GPIO Usage Considerations Applications Note.
you may also check Topic 76100 for default pull configuration and strength for GPIOs on the Jetson Nano,
thanks
