As the title ,OpenCL can call tensor core ?
If OpenCL can call tensor core ,need install extension library?
There is no direct support for tensor core in NVIDIA OpenCL. Furthermore, AFAIK, NVIDIA does not support the khronos fp16 extension.
However the lack of fp16 extension can be worked around manually, and it is possible to access tensor core from OpenCL code via inline PTX. Using that methodology, no extension libraries are needed.
Here is a full example:
$ cat t15.cpp
#include <stdlib.h>
#include <iostream>
#include <string>
#include <cstring>
#include <CL/cl.h>
using namespace std;
#define testpp(...)#__VA_ARGS__
const char* pp = testpp(
__kernel void mma_8x8x4_fp16_acc_fp32(__global float *out) {
float c[8] = {0., 0., 0., 0., 0., 0., 0., 0.};
float d[8] = {0., 0., 0., 0., 0., 0., 0., 0.};
unsigned short a[4] = {15360, 15360, 15360, 15360};
unsigned short b[4] = {15360, 15360, 15360, 15360};
const unsigned *A = (const unsigned *)&a;
const unsigned *B = (const unsigned *)&b;
const float *C = (const float *)&c;
float *D = (float *)&d;
asm(
"mma.sync.aligned.row.col.m8n8k4.f32.f16.f16.f32"
"{%0,%1,%2,%3,%4,%5,%6,%7}, {%8,%9}, {%10,%11}, {%12,%13,%14,%15,%16,%17,%18,%19};\n"
: "=f"(D[0]), "=f"(D[1]), "=f"(D[2]), "=f"(D[3]), "=f"(D[4]), "=f"(D[5]), "=f"(D[6]), "=f"(D[7])
"r"(A[0]), "r"(A[1]),
"r"(B[0]), "r"(B[1]),
"f"(C[0]), "f"(C[1]), "f"(C[2]), "f"(C[3]), "f"(C[4]), "f"(C[5]), "f"(C[6]), "f"(C[7])
int tidx = get_global_id(0);
for (int i = 0; i < 8; i++) out[tidx*8+i] = D[i];
float out[256];
int main()
cl_int err = 0;
cl_uint numPlatforms;
cl_platform_id platform = NULL;
int ans;
err = clGetPlatformIDs(0, NULL, &numPlatforms);
if (err != CL_SUCCESS)
cout << "Error: Getting Platforms\n";
return EXIT_FAILURE;
if (numPlatforms > 0)
cl_platform_id* platforms = (cl_platform_id*)malloc(numPlatforms * sizeof(cl_platform_id));
err = clGetPlatformIDs(numPlatforms, platforms, NULL);
cout << "Error: Getting Platform Ids.(clGetPlatformIDs)\n";
cout << "available platforms: " << endl;
for (unsigned int i = 0; i < numPlatforms; ++i)
char pbuff[100];
err = clGetPlatformInfo(platforms[i], CL_PLATFORM_VENDOR, sizeof(pbuff), pbuff, NULL);
cout << i << ":" << pbuff << "\n";
cout << "select platform: ";
cin >> ans;
if (ans < numPlatforms) platform = platforms[ans];
else {cout << "invalid platform choice" << endl; return EXIT_FAILURE;}
free(platforms);
else
cout << "no platforms found\n";
cl_uint num_devices = 0;
cl_device_id* devices = NULL;
cl_device_id device = NULL;
err = clGetDeviceIDs(platform, CL_DEVICE_TYPE_ALL, 0, devices, &num_devices);
if (num_devices == 0) //no GPU available.
cout << "No GPU device available." << endl;
else
devices = (cl_device_id*)malloc(num_devices * sizeof(cl_device_id));
err = clGetDeviceIDs(platform, CL_DEVICE_TYPE_GPU, num_devices, devices, NULL);
cout << "available devices: " << endl;
for (unsigned int i = 0; i < num_devices; ++i)
char pbuff[100];
err = clGetDeviceInfo(devices[i], CL_DEVICE_NAME, sizeof(pbuff), pbuff, NULL);
cout << "select device: ";
cin >> ans;
if (ans < num_devices) device = devices[ans];
else {cout << "invalid device choice" << endl; return EXIT_FAILURE;}
free(devices);
cl_context context = nullptr;
context = clCreateContext(NULL, 1, &device, NULL, NULL, &err);
cl_command_queue commandQueue = nullptr;
commandQueue = clCreateCommandQueue(context, device, 0, &err);
size_t ppsize[] = { strlen(pp) };
cl_program pprog = clCreateProgramWithSource(context, 1, &pp, ppsize, &err);
cout << "Error: Loading Binary into cl_program (clCreateProgramWithBinary)\n";
err = clBuildProgram(pprog, 1, &device, NULL, NULL, NULL);
if (err == CL_BUILD_PROGRAM_FAILURE) {
// Determine the size of the log
size_t log_size;
clGetProgramBuildInfo(pprog, device, CL_PROGRAM_BUILD_LOG, 0, NULL, &log_size);
// Allocate memory for the log
char* log = (char*)malloc(log_size);
// Get the log
clGetProgramBuildInfo(pprog, device, CL_PROGRAM_BUILD_LOG, log_size, log, NULL);
// Print the log
cout << log << endl;
cout << err;
printf("Error: Building Program (clBuildProgram)\n");
cl_kernel testkernel = clCreateKernel(pprog, "mma_8x8x4_fp16_acc_fp32", &err);
size_t log_size;
// Get the log
// Print the log
cout << "Error: Creating Kernel from program.(clCreateKernel)\n";
cl_mem outbuff = clCreateBuffer(context, CL_MEM_READ_WRITE | CL_MEM_COPY_HOST_PTR, sizeof(float) * 256, &out, &err);
err = clSetKernelArg(testkernel, 0, sizeof(cl_mem), (void*)&outbuff);
size_t globalThreads = 32;
size_t localThreads = 32;
err = clEnqueueNDRangeKernel(commandQueue, testkernel, 1, NULL, &globalThreads, &localThreads, 0, NULL, NULL);
cout << "Error: Enqueueing kernel\n";
err = clFinish(commandQueue);
cout << "Error: Finish command queue\n";
err = clEnqueueReadBuffer(commandQueue, outbuff, CL_TRUE, 0, sizeof(float) * 256, &out, 0, NULL, NULL);
for (int i = 0; i < 16; i++){
for (int j = 0; j < 16; j++)
cout << out[i*16+j] << " ";
cout << endl;
$ nvcc -o t15 t15.cpp -lOpenCL
$ ./t15
0:NVIDIA Corporation
select platform: 0
0:Tesla V100-PCIE-32GB
1:Tesla K20Xm
2:Tesla K20Xm
3:Tesla K20Xm
select device: 0
4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
(CUDA 11.4, driver 470.57.02)
A few notes:
- the constant 15360 in the above code represents the
unsigned shortrepresentation of fp16 value of 1.0 - the lack of a fp16 extension can be worked around “manually”. As a “roadmap”, you could do something like what njuffa did here. I’m not suggesting it is drop-in ready-to-go, just a general sketch of how to do it.
- the matrix result of all 4 above is expected. The selected mma operation does four m=8, n=8, k=4 matrix-multiply operations per warp. Therefore there are 256 total result elements, and since k=4, and both input matrices are all 1.0, 4 is the expected result for each element.
