AIM:
I am using caffe.
I am trying to run program on tx2 as on my x64 computer.
I always check out version between them and it indeed help me a lot.
I think this maybe because the version about opencv or cv2 module.
However I don’t know how to change my cv2 module version on TX2.
If you need more environment information, please reply me.
Environment:
example:
import cv2
print cv2.version
DEVICE: TX2
python 2.7
python modle:
matplotlib 2.2.2
pylab 1.11.0
cv2 2.4.13
JetPack: 3.0 (more info: https://developer.nvidia.com/embedded/jetpack-3_0)
moreinfo:
when I tried
sudo apt-get install libopencv-dev
error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libopencv-dev : Depends: libopencv-core-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-ml-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-imgproc-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-video-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-objdetect-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-highgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-flann-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-legacy-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-contrib-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-ts-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-photo-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-videostab-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-stitching-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-gpu-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-superres-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libopencv-ocl-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed
Depends: libopencv2.4-java (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed
Depends: libopencv2.4-jni (= 2.4.9.1+dfsg-1.5ubuntu1.1) but it is not going to be installed
Depends: libcv-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libhighgui-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
Depends: libcvaux-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
E: Unable to correct problems, you have held broken packages.
I learn that if I install JetPack I cannot change opencv as this way:
, right?
then when I try to
import cv2
in python. I meet error:
No module named cv2
so I search an anwser and do it as follow:
sudo apt-get install libopencv4tegra-python
sudo apt-get install opencv-python
and
libopencv4tegra-python: 2.4.13-17-g5317135
When I try this code:
pkg-config opencv --modversion
TX2 DEVICE:
2.4.13
my x64 computer DEVICE
2.4.9.1
When I try this code in python:
import cv2
print cv2.__version
TX2 DEVICE:
2.4.13
3.4.3
When I run under code:
rectmap = {}
imgid=0
imgdir= datadir+'666.jpg'
img = load_img(imgdir)
imgdata = img[:,:,[2,1,0]]*255. - mn
all_rect = []
sys.stdout.flush()
work(imgdata, all_rect)
rectmap[imgid] = all_rect
result_annos = anno_func.get_refine_rects(annos, rectmap)
print result_annos['imgs'].keys()
print result_annos['imgs'][imgid]
imgdata_draw = anno_func.draw_all(result_annos,datadir,imgid,img)
pl.figure(figsize=(20,20))
pl.imshow(imgdata_draw)
There is error:
Traceback (most recent call last)
<ipython-input-10-5e956b4ea70a> in <module>()
8 all_rect = []
9 sys.stdout.flush()
---> 10 work(imgdata, all_rect)
11 rectmap[imgid] = all_rect
12 result_annos = anno_func.get_refine_rects(annos, rectmap)
<ipython-input-8-46f307e2a988> in work(imgdata, all_rect)
42 data = cv2.resize(imgdata, (data_layer.shape[2], data_layer.shape[3]))
43 else:
---> 44 data = cv2.resize(imgdata, (imgdata.shape[0]*resize, imgdata.shape[1]*resize))
45 data = data.transpose(2,0,1)
46 #print data.shape
error: /hdd/buildbot/slave_jetson_tx_3/35-O4T-L4T-R24/opencv/modules/python/src2/cv2.cpp:201: error: (-2) The numpy array of typenum=12, ndims=3 can not be created in function allocate
I will appreciate it if you can give me some suggestion !
