opencv with cuda support (solved)
Hello forum,
I am new to Cuda at all.
I built an opencv color detection routine on a raspberry Pi in c++ the other day.
With high resolution it is far to slow, so I want to use the GPU Power of the Jetson Nano.
I installed the standard jetson nano SD jetson-nano-sd-r32.1-2019-03-18.zip
I can compile opencv c++ programs.
As expected they are slower than the raspberry pi programs as the CPU is slower.
Now I want to use GPU power, but I cannot find the opencv2/gpu.hpp.
I expect the nvidia guys to have the gpu extension installed into the opencv2-system.
Is this wrong?
How do I procede now?
If anyone want to help me even further:
I want to do a color detection in a 1280x720@120fps stream coming from a CSI Cam.
I wanted to do it the standard way : blure, hsv, treshold, detect
and I wanted to do this on GPU instead of CPU.
This would only include using cv::gpu:GpuMat instead of CV::Mat , right?
But is this the best way?
I am sure, I am not the first one trying to do so.
So I would be glad if anyone helped me.
Greetings,
Roland
Is this wrong?
→ Sorry that this is wrong. The opencv from sdkmanager is w/o cuda.
Please follow up the installation from public openCV tutorial to enable cuda support.
Hi Wayne,
thanks for your answer.
I found tons of building instructions for opencv4 with cuda,
but I think you had a reason choosing opencv2.4 with the JetPack.
Can you give me a link to an “out of the box instruction” how to enable cuda on the standard opencv on the jetson nano?
Or would you recommend purgeing that all and start with a new opencv4 ?
Greetings,
Roland
The reason behind using cv2.4 is because old jetpack has used opencv2.4 for a long time. But we don’t recommend it anymore.
You could use below scripts to install it.
https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.0.0_Nano.sh
Hi Wayne, thanks again!
Ok, I will try do run this script.
There is no readme for this on github.
Do I need to “prepare” the nano first?
(like creating swap, using bigger SD Card, switching anything on or off?)
thank you!
Roland
I think you may require a bigger sdcard.
Ok, I have a 32GB card and I flashed a new image on it.
Do I need to do anything else?
sorry for beeing a newbee…
Roland
Ok, I made it.
I created a 6GB Swap drive and followed the script:
Works fine and opencv4 with cuda is working.
I have some more problems actually using it, but this is another topic.
This one can be closed.
