I followed this https://github.com/JetsonHacksNano/buildOpenCV to build opencv 4.2 on jetson nano with CUDA support
Then I tried This code to capture from raspberry pi v2.1 camera
#include <opencv2/opencv.hpp>
#include <opencv2/core/cuda.hpp>
#include <algorithm>
#include <chrono>
#include <iostream>
using namespace std;
using namespace std::chrono;
std::string gstreamer_pipeline (int capture_width, int capture_height, int display_width, int display_height, int framerate, int flip_method) {
return "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)" + std::to_string(capture_width) + ", height=(int)" +
std::to_string(capture_height) + ", format=(string)NV12, framerate=(fraction)" + std::to_string(framerate) +
"/1 ! nvvidconv flip-method=" + std::to_string(flip_method) + " ! video/x-raw, width=(int)" + std::to_string(display_width) + ", height=(int)" +
std::to_string(display_height) + ", format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink";
int main()
int capture_width = 3264 ;
int capture_height = 2464 ;
int display_width = 3264 ;
int display_height = 2464 ;
int framerate = 30 ;
int flip_method = 0 ;
std::string pipeline = gstreamer_pipeline(capture_width,
capture_height,
display_width,
display_height,
framerate,
flip_method);
std::cout << "Using pipeline: \n\t" << pipeline << "\n";
cv::VideoCapture cap(pipeline, cv::CAP_GSTREAMER);
if(!cap.isOpened()) {
std::cout<<"Failed to open camera."<<std::endl;
return (-1);
cv::Size new_size(1080,720);//the dst image size,e.g.100x100
cv::cuda::GpuMat dst;//dst imag
cv::namedWindow("CSI Camera", cv::WINDOW_AUTOSIZE);
cv::cuda::GpuMat img;
std::cout << "Hit ESC to exit" << "\n" ;
while(true)
auto start = high_resolution_clock::now();
if (!cap.read(img)) {
std::cout<<"Capture read error"<<std::endl;
break;
cv::resize(img,dst,new_s);//resize image
cv::imshow("CSI Camera",dst);
auto stop = high_resolution_clock::now();
auto duration = duration_cast<milliseconds>(stop - start);
float time = duration.count() / 1000.0;
float fps = 1.0 / time;
cout << "FPS: "<<fps<< endl;
int keycode = cv::waitKey(30) & 0xff ;
if (keycode == 27) break ;
cap.release();
cv::destroyAllWindows() ;
return 0;
Using GpuMat gives this error: “OpenCV Error: No CUDA support (The library is compiled without CUDA support) in throw_no_cuda, file /home/nvidia/build_opencv/opencv/modules/core/include/opencv2/core/private.cuda.hpp, line 107
terminate called after throwing an instance of ‘cv::Exception’
what(): /home/nvidia/build_opencv/opencv/modules/core/include/opencv2/core/private.cuda.hpp:107: error: (-216) The library is compiled without CUDA support in function throw_no_cuda”
with cv::Mat every thing goes right but the frame rate is 18 FPS, I need Higher fps for my app
is there is any way to accelerate the capturing process using cuda ?
