Reading CSI camera input directly to GPU memory
I have an application uses jetson nano. I’m using gstreamer pipeline to read from csi camera (imx-219) using opencv and do all image processing stuff in cuda. All works ok, I’m using appsink to read in opencv capture and upload frame to gpu.
So my pipeline is like this basically,
Gstreamer → Opencv → Cuda
However, I cannot achieve desired fps (~28fps) since my cuda kernels are also time consuming and copying from host to device takes a lot of time. (I’m using cuda streams as well)
I was curious is it possible to put image directly in gpu memory without uploading from cpu to gpu. I really don’t know the underlying structure and this might be a silly question.
I don’t need the frame in cpu at first but later I need to download the image to stream it.
Is this possible? Also with this solution can I increase the fps rate of my program?
I would suggest using MMAPI like cudaBayerDemosaic/cudaHistogram for your case.
Capturing from nvarguscamerasrc with gstreamer, you would have the buffers into NVMM memory ready for GPU processing. If your processing doesn’t change resolution, you may use nvivafilter that can perform CUDA processing on NVMM buffers (RGBA or NV12, the latter may have stride constraint).
As an example of using opencv/cuda from nvivafilter, see:
Thank you for your responses, actually I was looking for this : the buffers into NVMM memory ready for GPU processing.
Now it makes sense for me to use CSI camera, my processing involves opencv::cuda functions as well, I will check the proposed solutions and update this thread.
Okay now I found what I was looking for, actually @Honey_Patouceul the answer was one of your old posts :
gpu-acceleration-support-for-opencv-gstreamer-pipeline
So if someone encounters the same problem as I did, I wanted to contribute with a simple example as well. @dusty-nv’s jetson-utils library actually provides an easy use of capturing image and handling it inside the NVMM memory. (Just compile it with -DNVMM_ENABLE=1)
I also wrote a simple test script to check the actual result, this example for my csi camera. Using gstcamera of jetson-utils library allows you to handle the frame in cuda or even as cv::cuda::GpuMat.
void trying_jetsonutils(){
	std::cout << "Trying NVMM read" << std::endl;
	// create input stream
	videoOptions opt;
	opt.width  = 3264;
	opt.height = 1848;
	opt.frameRate = 28;
	opt.zeroCopy = false; // GPU access only for better speed
	opt.resource = "csi://0";
	// videoSource * input = videoSource::Create("csi://0", opt);
	gstCamera * input = gstCamera::Create(opt);
	if (!input) {
		std::cerr << "Error: Failed to create input stream" << std::endl;
		exit(-1);
	// Read one frame to get resolution
	uchar3* image = NULL;
	if( !input->Capture(&image, 1000) )
		std::cerr << "Error: failed to capture first video frame" << std::endl;
		delete input;
		exit(3);
	cv::cuda::GpuMat dummy_frame(input->GetHeight(), input->GetWidth(), CV_8UC3);
	int i = 0;
	std::chrono::high_resolution_clock::time_point start_time;
	std::chrono::high_resolution_clock::time_point end_time;
	std::chrono::microseconds duration;
	while( 1 ){
		// capture next image
		if( !input->Capture(&image, 1000) ){
			std::cerr << "Error: failed to capture video frame" << std::endl;
			continue;
		// Some OpenCv processing
		start_time = std::chrono::high_resolution_clock::now();
		cv::cuda::GpuMat frame_in(input->GetHeight(), input->GetWidth(), CV_8UC3, image);
		end_time = std::chrono::high_resolution_clock::now();
		duration = std::chrono::duration_cast<std::chrono::microseconds>(end_time - start_time);
		std::cout << "Upload duration: " << duration.count() << " us "<< std::endl;
		cv::cuda::cvtColor(frame_in, dummy_frame, cv::COLOR_RGB2GRAY);
		std::cout << "CvtColor duration: " << duration.count() << " us "<< std::endl;
		cv::Mat cpu_frame;
		dummy_frame.download(cpu_frame);
		std::cout << "Download duration: " << duration.count() << " us "<< std::endl;
		cv::imwrite("gpu_frame.png", cpu_frame);
		if( !input->IsStreaming() )
			break;
		if (i > 10)
			break;
		i++;
	delete input;
The upload time is around ~2us right now comparing to my old test it was around ~25000us which means the image pointer is not copied because it was already in the memory that gpu can handle.
