OpenGL VBO
Hi, I have created a Vertex Buffer Object in my project quite similar to the simpleGL example but I am having problems rendering it correctly.
In my kernel (for testing) I say
[codebox]vbo[0] = make_float3(0.0f, 0.0f, 0.0f);
vbo[1] = make_float3(0.0f, 1.0f, 0.0f);
vbo[2] = make_float3(1.0f, 1.0f, 0.0f);
vbo[3] = make_float3(1.0f, 0.0f, 0.0f);[/codebox]
and then back in my OpenGL display() function I do this
[codebox]cutilCheckError(cutStartTimer(timer));
float modelView[16];
glMatrixMode(GL_MODELVIEW);
glPushMatrix();
    glLoadIdentity();
    glRotatef(-ViewRot.x, 1.0, 0.0, 0.0);
    glRotatef(-ViewRot.y, 0.0, 1.0, 0.0);
    glTranslatef(-ViewTrans.x, -ViewTrans.y, -ViewTrans.z);
	glGetFloatv(GL_MODELVIEW_MATRIX, modelView);
glPopMatrix();
invViewMatrix[0] = modelView[0];
invViewMatrix[1] = modelView[4];
invViewMatrix[2] = modelView[8];
invViewMatrix[3] = modelView[12];
invViewMatrix[4] = modelView[1];
invViewMatrix[5] = modelView[5];
invViewMatrix[6] = modelView[9];
invViewMatrix[7] = modelView[13];
invViewMatrix[8] = modelView[2];
invViewMatrix[9] = modelView[6];
invViewMatrix[10] = modelView[10];
invViewMatrix[11] = modelView[14];
CalculateWithCUDA();		// CUDA calculates what to render
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glDisable(GL_DEPTH_TEST);
glRasterPos2i(0, 0);
glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB, iPBO);	// Draw image from Pixel Buffer Object
glDrawPixels(screenWidth,screenHeight, GL_RGBA, GL_UNSIGNED_BYTE, 0);
glBindBufferARB(GL_PIXEL_UNPACK_BUFFER_ARB, 0);
glPushMatrix();	// Draw the Vertex Buffer Object over the PBO?
	glLoadIdentity();
	glBindBuffer(GL_ARRAY_BUFFER, iVBO);
	glVertexPointer(4, GL_FLOAT, 0, 0);
	glEnableClientState(GL_VERTEX_ARRAY);
	glColor3f(0.0, 1.0, 0.0);
	glDrawArrays(GL_QUADS, 0, 4);
	glDisableClientState(GL_VERTEX_ARRAY);
	glBindBufferARB(GL_ARRAY_BUFFER_ARB, 0);
glPopMatrix();
glutSwapBuffers();
cutilCheckError(cutStopTimer(timer));
ComputeFPS();[/codebox]
as you can see I am also using a Pixel Buffer Object (as seen in the volume rendering example).
What I want to try to create (in the end) is a “wireframe” style cube around my pixel buffer data (which is a cube) but even trying to draw a simple quad as shown above doesnt come out right and I’m not smart enough to see why!
I end up with a triangle instead of a quad and I dont think its between 0-1 like the data I assigned in my kernel, anyone got any ideas on this one?
