I 'm try to compile openmpi with infiniband suport using pgi 7.0 .
running RHEL4 U4,
OFED 1.1
my configure line is :
./configure --prefix=/opt/openmpi.pgi --with-openib=/usr/local/ofed --with-openib-libdir=/usr/local/ofed/lib64 CC=pgcc CXX=pgCC F77=pgf77 FC=pgf90
got the following error when make
libtool: link: pgcc -shared -fpic -DPIC class/.libs/opal_free_list.o class/.libs/opal_hash_table.o class/.libs/opal_list.o class/.libs/opal_object.o class/.libs/opal_atomic_lifo.o class/.libs/opal_value_array.o memoryhooks/.libs/memory.o runtime/.libs/opal_progress.o runtime/.libs/opal_finalize.o runtime/.libs/opal_init.o runtime/.libs/opal_params.o threads/.libs/condition.o threads/.libs/mutex.o threads/.libs/thread.o -Wl,–whole-archive,libltdl/.libs/libltdlc.a,asm/.libs/libasm.a,event/.libs/libevent.a,mca/base/.libs/libmca_base.a,util/.libs/libopalutil.a,mca/backtrace/.libs/libmca_backtrace.a,mca/backtrace/execinfo/.libs/libmca_backtrace_execinfo.a,mca/installdirs/.libs/libmca_installdirs.a,mca/installdirs/config/.libs/libmca_installdirs_config.a,mca/installdirs/env/.libs/libmca_installdirs_env.a,mca/maffinity/.libs/libmca_maffinity.a,mca/memcpy/.libs/libmca_memcpy.a,mca/memory/.libs/libmca_memory.a,mca/memory/ptmalloc2/.libs/libmca_memory_ptmalloc2.a,mca/paffinity/.libs/libmca_paffinity.a,mca/timer/.libs/libmca_timer.a,mca/timer/linux/.libs/libmca_timer_linux.a -Wl,–no-whole-archive -ldl -lnsl -lutil -lpthread -lc -Wl,-soname -Wl,libopen-pal.so.0 -o .libs/libopen-pal.so.0.0.0
/usr/bin/ld: class/.libs/opal_free_list.o: relocation R_X86_64_PC32 against __pgio_ini' can not be used when making a shared object; recompile with -fPIC /usr/bin/ld: final link failed: Bad value make[2]: *** [libopen-pal.la] Error 2 make[2]: Leaving directory /opt/atipa/src/openmpi-1.2.2/opal’
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/atipa/src/openmpi-1.2.2/opal’
make: *** [all-recursive] Error 1
appreciate any help
-Brady
