I’m creating multiple AWS EC2 instances with CloudXR which will stream the same applications to different clients. Each instance appears to require 200GB of storage, I can’t launch the instance with less. With the applications installed I have about 100GB of empty space which I don’t need. Also, storing the same applications on each instance seems like a waste of resources. I think having the same or a shared drive with the applications to run would be good if this is this possible? Or could the instances share other files for storage optimization? I’m new to AWS so perhaps there is a solution for this that I’m unaware of.
Related topics
| CloudXR Multiple Client support on single server instance | 1 | 134 | September 9, 2024 | |
| CloudXR on AWS for UE4 .exe and Oculus Quest2 | 0 | 876 | June 22, 2022 | |
| A walkthrough video for from-scratch AWS windows setup | 0 | 155 | December 5, 2024 | |
| How to balance VR clients - CloudXr on Premise | 4 | 769 | May 15, 2023 | |
| CloudXR 3.1.1 on AWS G5 Instance | 6 | 1072 | January 7, 2025 | |
| Connect Multiple Clients on Single Cloud-XR Server | 1 | 806 | August 30, 2022 | |
| Unable to stream on AWS EC2 G5.4xlarge Instance but works on G4 Instance | 3 | 423 | May 29, 2024 | |
| Develop, Deploy, and Distribute Immersive Experiences with NVIDIA CloudXR and Amazon Web Services | 0 | 544 | December 27, 2021 | |
| Extreme latency when using CloudXR on AWS | 0 | 78 | August 16, 2024 | |
| How Can I setup EC2 instance ready for CloudXR 4.0 | 3 | 610 | December 1, 2023 |
