Hi All,
I’m about to design/develop a system that requires control of 2 analogue output. As there is no direct analogue output on the developer kit, as far as I know, I want to use a DAC chip.
Currently I’m looking at a MCP4822 DAC (a cheap dual channel 12 bit DAC), that uses a SPI interface. My question is, if this will work with the Jetson using Python without too much work? What are the alternatives?
Thanks in advance.
/Esben
