Hi all,
I’ve run into issues trying to use the OptiX-GL interop features in both my own applications and in running the samples.
Each sample, such as isgShadows, crashes with a detected error: Not a valid OpenGL texture. In my own work, I see an issue with trying to map an OptiX buffer bound to a PBO; OptiX seems to think the PBO size is zero, which I have verified everywhere to be false.
Useful info:
OptiX 3.9.1
Number of Devices = 1
Device 0: Quadro K1100M
Compute Support: 3 0
Total Memory: 2146762752 bytes
Clock Rate: 705500 kilohertz
Max. Threads per Block: 1024
SM Count: 2
Execution Timeout Enabled: 1
Max. HW Texture Count: 128
TCC driver enabled: 0
CUDA Device Ordinal: 0
Constructing a context…
Created with 1 device(s)
Supports 2147483647 simultaneous textures
Free memory:
Device 0: 1958088704 bytes
Graphics: Card: NVIDIA GK107GLM [Quadro K1100M] bus-ID: 01:00.0
Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa) Resolution: 3840x2160@60.00hz
GLX Renderer: Quadro K1100M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 361.42 Direct Rendering: Yes
UDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “Quadro K1100M”
CUDA Driver Version / Runtime Version 8.0 / 7.5
CUDA Capability Major/Minor version number: 3.0
Total amount of global memory: 2047 MBytes (2146762752 bytes)
( 2) Multiprocessors, (192) CUDA Cores/MP: 384 CUDA Cores
GPU Max Clock rate: 706 MHz (0.71 GHz)
Memory Clock rate: 1400 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 262144 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 7.5, NumDevs = 1, Device0 = Quadro K1100M
Result = PASS
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: Quadro K1100M/PCIe/SSE2
OpenGL core profile version string: 4.5.0 NVIDIA 361.42
OpenGL core profile shading language version string: 4.50 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5.0 NVIDIA 361.42
OpenGL shading language version string: 4.50 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 361.42
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
If you need any more info, please let me know.
